I was wondering if anybody else has come across this problem.I have a Pioneer 106 &107.Occasionaly when i am burning disks either cd or dvd with nero v6 when the % is at 100 it keeps on burning sometimes for minutes.I have both writers installed so i can multi burn.When i burn dvds the busy light can go of one burner but keep on the other and it will burn until the disk is completly full then give an error message.Then the disks will both play fine but one has taken 13 min the other can take anything up to 45 mins.Both copying the same source disk and both with the same Ritek RiDisc 4* DVD-R disks
Is there a way to cure this problem.
Thanks in advance.
Results 1 to 1 of 1
DVD overburning. Is it possible?
By eroy in forum DVD & Blu-ray WritersReplies: 53Last Post: 6th Sep 2010, 16:57 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39
