is there any special applications, or filters that will clean up grainy video that is usually produced by low light settings and using a low light mode on the camera.
thanks in advance.
If you'll be converting to DivX at all, the pre-processing source will clear grain up but at the cost of smoothing all the details out.
VirtualDub has a temporal smoother filter that you could use to remove grain, with the same sort of effects that the pre-processing has in DivX.
Cobra -
In that case, if you're using TMPGEnc, the noise reduction filter should do the trick.
Cobra
grainy dark video Help
By timbo2288 in forum RestorationReplies: 36Last Post: 17th Apr 2015, 18:48 -
Grainy video footage
By ccorwin in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2011, 02:24 -
grainy video in mpc
By thinkor in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2010, 17:10 -
Video quality is grainy
By Mysterio in forum Newbie / General discussionsReplies: 14Last Post: 5th Mar 2009, 13:03 -
Help With Grainy Looking Video
By MAXIMUS01CAN in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 30th Jan 2008, 17:00
