Its only a teaser for a goblin game but I want to try it before getting the actual game as I find some games are really bad and its worth trying before buying as they say.
I ahve these files within a .rar file.
Data Folder - in this file there is an audio folder and a data.baf file. In the audio file there are 3 more folders which hold PAK files, Scripts and IRX files etc
IOP Folder - has an ICO file and IRX files
SLUS_207.92 file
SYStem.CNF file
Truth.INI file
Anuone got any ideas what to do with these to get them on a dvd.
Also if anyone knows - I have another teaser that has 2 rare files - how do I get these on a DVD as one file. If I extract them I get 2 files but cant find a decent guide to put them together.
Thanks all.
well im hoping you have your ps2 chipped or else your out of luck. its been a long time since ive dealt with any ps2 backups, but you could try http://www.ps2ownz.com/
they used to have all kinds of info on what your looking for.Heres to alcohol, the cause of, and solution to all of lifes problems.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Ripping Audio from PS2 Game Bully?
By coondog1234 in forum AudioReplies: 2Last Post: 10th Mar 2010, 09:47 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
Need to Create a Teaser/ Pre Trailer on my DVD
By YOURCONNEXX in forum Authoring (DVD)Replies: 25Last Post: 26th Oct 2007, 19:45
