Im trying to buy DVD-r bigger than 4.7 GB
DO u know where i can get them, How do the movies dudes store 9GB on to 1 dvd
Results 1 to 15 of 15
Ok first off how does this constitute being NEWS?
secondly, as of right now you cant buy dvd-rs that r bigger than 4.7g. the reason commercial dvds hold more is that they are pressed and not burned.
next time search around for this info.Heres to alcohol, the cause of, and solution to all of lifes problems. -
Originally Posted by fma
The quick answer: No.
The long answer: There are several new formats on the horizon which will do to DVD what CDs did to the 3.5" floppy. You can find posts about them here in the "Latest News" forum. The one closest to becoming reality is the dual-layer DVD and burners which will offer 9GB, similar to the dual-layer commercial movies you rent now. They probably won't be called "DVD-R" because of confusion, but will probably be called "DVD-R9" or something like that, referring to the 9.4GB DVD-9 specification. -
OOOOOOOOOHHHHHHHH!
Are you going to regret this one.First, this is not news but a newbie media question. Second, essentially every DVD thread here is about this fact. All you needed to do was read a couple of the basic guides and you would have your answers.
Before the flaming starts, the simple answer to your question is that R and RW DVDs are 4.7 Gig right now and most commercial products are as you noted 9 Gig. There are essentially no 9 Gig disks or burners available right now. They are coming, probably soon, but for now everything is 4.7.
How do they make 9 Gig. I'm only going to answer this to clarify the nomenclature. They essentially glue a semi-trasparent 4.7 gig disk on top of another 4.7 Gig disk creating two layers. Therefore the soon to be comming 9 Gig burners and disks are called dual layer.
To answer what I hope is your next question. What this site is largely about when it comes to DVDs is either eliminating the extraneous materials from DVDs or re-encoding them at a lower bitrate, both with the goal of making a good quality movie that will fit on a single 4.7 Gig disk. -
Maybe you should ask for +R then you can just keep adding them together to acheive the desired size.
LOL.
You guys love these questions, you just cant resist a good old newbie question.
Hell, these questions sometimes generate more replies that one would imagine.
keep them coming. -
Stick 2 disks together.....
But remember to put the lable sides on the inside..Not bothered by small problems...
Spend a night alone with a mosquito -
hope this answers your question.
fma,
Buy the double-sided one. They are about $2.5 - $3.00. Each side holds 4.7GB.
Cheers, -
Plus, I'm surprised there arent more posts making fun of this guy...whats wrong with you people? Are you in a good mood today?
And yes, this is a completely useless post, since the question was already answered multiple times.-Yar, matey!- -
i sell 6.7 gig dvd+r. send me a hundred bucks, i'll send you 10 dvd+R6.5
It is possible to buy 9Gb media now..3 different types..
1 dvdram double sided ($6-$9)
2 dvd-r 8.5gb (quantities of 10,000+)*
3 dvd+r 8.5gb (quanitities of 16,300+)*
*These can only be pressed not burntCorned beef is now made to a higher standard than at any time in history.
http://www.rima.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=R&Category_Code=DVR94
These are DVDs with 4.7GB recordable surfaces on both sides of the disc.
Dual-layer recordable DVDs are on the way. If you believe the news reports we'll have the recorders and the media available in the next couple of months...
For now, you must rip and/or shrink.
21.7GB on a DVD?
By sebrame in forum Authoring (DVD)Replies: 8Last Post: 1st Feb 2010, 15:56 -
ipod touch video playing at 2x or greater?
By extremelyslow in forum MacReplies: 0Last Post: 3rd Feb 2009, 17:41 -
Music volume is greater than people speaking
By Alvito in forum AudioReplies: 3Last Post: 24th Dec 2008, 17:23 -
7GB .iso to DVD
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2008, 08:26 -
Formatting a dvd-rw 4.7gb
By IOMEGA in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 14:56
