I have these VCD's here, and they are loaded with RM files....
My DVD player cannot play them, so I cant simply capture the video into my computer, and none of the programs I have can do it.
Does anybody know a way to transfer Real Media(.RM) files into a format that i can use, such as .avi, .mpeg, or .vob?
Thanks.
TMPEGEnc can do just about every format that exists EXCEPT .RM
This is crazy all i want to do is take this worthless CD and make it into a DVD so i can actually watch the stupid thing.
Ive been working with video like this for years, and never have I been able to do .RM
Not even Adobe Premier PRO can use .RM files... -
Try these :
http://www.mpgdvd.com/avone_rm/
http://www.softcities.com/RM-Converter/download/1810.htm
This software is a freeware converter of RM to AVI I found
http://members.fortunecity.com/tinra04/
This is the GUI for the above converter
http://guiguy.wminds.com/downloads/tinragui/index.html -
@hellfire45
-pop cd in cd-rom of computer
-open tracks using RealOne player,
-choose 'CD' on the bottom of the application.
-click on add track
-browse and add tracks.
-burn on to cd-r/rw as .wav format and it is easy to convert to mp3 or any other format from there.Don't waste your media. Burn it on re-writable media first.
WTV/DVR-MS files into usable MPEG format?
By CursedLemon in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 09:21 -
RAM .vro files to usable format?
By nelsh in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 19:05 -
Need advice on converting MOD (mpeg2) files to usable format for iMovie
By InsanelyOne in forum MacReplies: 3Last Post: 9th Sep 2007, 15:23 -
trying to convert VOB TV files into something usable on my computer
By sipapu in forum Video ConversionReplies: 5Last Post: 27th Jun 2007, 11:49 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
