I have captured some TV shows using my Pinaccle Deluxe unit and two of the captures are way OOS. The captures are typically 1 - 3 hour blocks and I have about 15 blocks done with no problems. As mentioned, for some reason, these two captures, when viewed using Womble and Winamp show the video racing ahead of the video. I haven't actually figured out the time, but guess at least 2 minutes and it appears to increase as it goes. Also winamp reports the clip time at 10 minutes but it is at least one hour in length.
Capturing was done at 240x480, 44.1 kHz.
Is there any way of 'fixing' this problem. I've search the forum but was anauble to locate anything specifically rleated, only somethin about demuxing the streams. If this is the way to fix, is there a guide or can someone provide a somewhat detailed procedure to follow.
Thanks in advance.
