Is easier to edit an Avi file than a Mpeg file?
I captured from my sony-TRV33 DV camcorder an avi file Type 1, then i tried to edit with virtualdub(just cut and join), but it did wrong(when i watch the edited video without (for) or (rew) it looks a sound good, but at the time i use them it loses the audio ),then i use Tmpenc and somehow the audio file is bigger than the video file. the don match. what should i do to fix the video, or maybe capture again using type II and use another edit program?
I would suggest capturing the file again, and this time in AVI format. This is the best format for editing in (MPEG has compression that sometimes can mess things up). Also, if you have a big hard drive, import in Uncompressed AVI, it makes editing so much easier!
Virtualdub is great for editing, but next time capture in Type II.
Uncompressed if you have the room.Cheers, Jim
My DVDLab Guides
Virtual Dub editing MP4 and WMV files with new plugin
By brevardo in forum EditingReplies: 5Last Post: 14th Jan 2011, 12:26 -
Editing and syncronising text in virtual dub
By santolina in forum EditingReplies: 4Last Post: 23rd Jul 2009, 18:29 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06 -
Virtual Dub 1.8.5 Editing question
By zenzen1 in forum EditingReplies: 3Last Post: 27th Sep 2008, 05:55 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27
