While converting a avi movie file with AC3 audio to mpeg1, I keep getting Invalid Pointer Operation. I tried several avi file and got the same result. I used divx 5.05 and recently installed the AC3 decompressor. It is on my PII centeron.
Is it the codec? If so, what is another codec I can use?
Is it the machine, too slow?
I used VirtualDub to verify for errors, but it did not detect anything. As an alternative, I used Virtual Dub to save the wav file and use TMPGenc to convert back to mpeg1 but there was no audio after 1/3 of the movie started.
Can anyone shed some light here?
Thanks,
Rage
Your machine is slow but I used to convert to mpeg1 on my AMD K6 II so it ain't your machine IMHO. For troublesome avi files try frameserving the video via vdub.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
As above, but I would also suggest scanning the file for bad frames also.
1. Try to increase your DirectShow Multimedia Reader plugin priority
2. Use VirtualDub to extract the audio to .wav and then use that for Audio Source in TMPGEnc
3. Do the same as above except after you extract the audio, select Audio>WAV Audio from the menu & frameserve to TMPGEnc -
Originally Posted by VCDHunter
[VirtualDub] How to split avi to x parts with one operation?
By ralf07 in forum Video ConversionReplies: 3Last Post: 5th Apr 2012, 17:01 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
Invalid Pointer error #80004003 PowerDVD - solved
By montrealer in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2009, 08:49 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 14:46 -
vista DVD maker invalid pointer
By sue1951 in forum Authoring (DVD)Replies: 1Last Post: 19th Jul 2007, 10:04
