Dear all,
I'm just a stupid newbie in VCD making. I captured avi files from DVcam (Dusing Adobe Premiere. In the very first test, I captured clips in short (about 1-2 mins). I can make the VCD by using Nero 5.5 for converting and burning the CD with no problem at all.
After that, I captured a clip at about more than 10 mins to try. I did the same procedure to burn the VCD with Nero. When I playback at the beginning of the clip is OK but at about 4min later the sound is completely gone... no sound at all actually but the picture stil look OK.
Could anyone tell me what this problem is about? And of course, how could I solve this problem?
I use PC (PentiumIII-750Mhz) with:
384MB Ram
7200rpm 40GB Hdd
Win2000
Thank you in advance.
from
Stupid VCD maker
Here's how I do it:
1) Use TMPGEnc for MPEG-encoding. I do this by useing the AVISynth and frameserve TMPEnc directly from Adobe Premiere. Advantage of this is that if You do any edit's and stuff to Your clip before creating the VCD, You don't have to save a new AVI before encoding the VCD mpeg.
2) I use GNU VCDImager and CDRDAO to burn the VCD. Haven't failed so far. You could also create a Nero compliant image and use Nero to burn it I guess...
The frameserving bit can be somewhat hard to set up at times (in my case mainly because I have several versions of the plug-in and AVISynth, and I always manage to mix the versions when installing). There are easy "follow-me" type of instructions for this though...
/Rico
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 18:41 -
Any MIDI gurus around here?
By sdsumike619 in forum ComputerReplies: 19Last Post: 26th May 2009, 01:49 -
Any MIDI gurus here? re: SCD-10
By sdsumike619 in forum AudioReplies: 0Last Post: 22nd Oct 2008, 23:35 -
Any Hardware Gurus Out There: I'm trying to install OS on AMD64
By wiseant in forum ComputerReplies: 9Last Post: 6th Mar 2008, 02:11 -
Question for NR gurus...
By takearushfan in forum AudioReplies: 11Last Post: 28th May 2007, 20:00
