Before everyone starts making crude comments about the title of this post, I need to ask a question.
Does the AVT-8710 do a full strip of the timing signal and then replace the horizontal and vertical syncs?
I was talking with a guy yesterday who represents AVT in my home town, and he wasn't sure that it would.
If it doesn't, then how can it defeat CSGM/A, which is, I believe, what you guys have said it does?
I just want to have proper information when he calls me back, so I can determine if he's selling me a line of crap or not.
Thanks for all the help!
Mechworker
I'm not sure how it works, but it does. I haven't seen a tape or dvd yet that will give this unit a problem as far as copy protection is concerned. 8)
https://secure3.nexternal.com/shared/StoreFront/default.asp?CS=avtoolbox&BusType=BtoC&...unt2=622962594
View Enlarged Image
AVT-8710 TBC is a Multi-system Time Base Corrector/Frame Synchronizer that accommodates most NTSC, PAL and SECAM video signal standards. It eliminates picture jitter and time base errors from videotape playback and insures a stable on-screen image through the use of dual-field full-frame reconstruction. It restores distorted or misshapen vertical and horizontal sync and color burst signals. An integral Processing Amplifier allows the adjustment of Brightness, Contrast, Color Saturation, Hue and Sharpness. A Digital Comb Filter provides superior video signal decoding and the AGC (Automatic Gain Control) insures a proper one volt output signal from an input signal range of 0.5 to 2.0 volts. A built-in Color Bar Generator sends out a test pattern when there is no video input. The unit has Composite Video and S-Video In and Out and comes with an external 12VDC Power Adapter.
AVT-8710 Key Features
* Video Input: Composite Video and S-Video
* Video Output: Composite Video and S-Video
* Video Standards: NTSC, NTSC 4.43, PAL (B, D, G, I, K), PAL-M, PAL-N and SECAM
* Video Adjustments: Brightness, Contrast, Color, Tint (NTSC) and Sharpness
* Built-in Color Bar Generator
* Automatic Gain Control
* Size 1.3" High x 3.5" Wide x 5.7" Deep ( 33mm x 90mm x 145mm )
* Weight 7 ounces (0.2kg)
* 115VAC to 12VDC Power Adapter includedWant my help? Ask here! (not via PM!)
Problems capturing with AVT-8710
By Tafflad in forum Capturing and VCRReplies: 1Last Post: 9th Feb 2010, 08:45 -
AVToolbox AVT-8710 TBC
By maeks84 in forum RestorationReplies: 3Last Post: 28th Apr 2008, 01:37 -
Help with AVT-8710 TBC
By Reniamatic in forum RestorationReplies: 2Last Post: 17th Sep 2007, 16:26 -
Panasonic e80h and the AVT-8710
By rmmd in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Sep 2007, 14:03 -
AV Toolbox AVT-8710?
By hip_school_preppie in forum Capturing and VCRReplies: 4Last Post: 30th May 2007, 19:43
