I have been using Flaskmpeg since January and really liked the interface. I have a client that gets PAL dvds as the original master and I simply need to be able to rip them. Especialy since a new batch will probably be here next week!!!
Anyways I went to there site and it's down I guess. Did Microsoft somehow make it so it doesn't work anymore?
Anyhow can someone recommend a similar program? Nothing incredibly fancy. I just need a straight transfer to AVI that will also rip the AC3 file.
true to the tri
Yeah I tried that one but I couldn't figure out how to get it to rip the whole thing. I must be missing some setting somewhere.
I'm trying DVDx 2.2. So far it seems it will do what I need.
I downloaded the latest version of FlaskMPEG both the regular and the beta. Can't get them to work right. Really sucks because this program worked so well for so long and was very easy and flawless.true to the tri -
I sympathize with you, Flask was simple and easy. Now it don't work.
I think i can narrow it down for you though. Delete the AVI-Out plugin, as well as the contents of the Settings folder, and Mine seems to work fine.
Flask refused to restart unless i deleted the contents of the settings folder.
I've considered using the AVI-Out plug from Mpeg Mediator, but never got around to it.
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
Hello My dvd shrink 3.2 does not work anymore
By Seekyr in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2009, 19:14 -
Videos don't work anymore
By SINZAR in forum Software PlayingReplies: 5Last Post: 14th Mar 2008, 12:46 -
Decode with quicktime does not work anymore
By macuser1960 in forum ffmpegX general discussionReplies: 8Last Post: 16th Jan 2008, 04:21 -
Help! My Dvd Player Won't Mp3's Anymore
By Just8 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Jul 2007, 23:08
