    Apr 2004
    Canada
    I'm newbie and I made a dvd using tpmgenc, the movie was composed with 2 avi files. Now I want to make the inverse conversion to retrieve the two original avi files because I found subtitles. How can I do it. I tried virtualdub but there are more vob files than the 2 avi I had.
    Help
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Help
    duhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    Dude you converted AVI to MPEG-2 DVD spec
    Your AVI is GONE ...
    For best quality you can rip the DVD and extract the MPEG-2 VIDEO and the AUDIO (which can be PCM WAV, MPA/MP2 or AC-3 depending on what you used).
    So do that then re-author using SELECTABLE SUBTITLES
    This way you will not loose any quality.
    If you want to burn-in the subs then you will be re-encoding your files a second time (AVI --> MPEG-2 ---> MPEG-2)
    Thus there will be a loss in quality.
    - John "FulciLives" Coleman
    Apr 2004
    Canada
    Thanks but which the best program to do that ?
  4. Member FulciLives's Avatar
    May 2003
    Use DVD Decrypter to rip the movie in IFO MODE and do STREAM PROCESSING.
    If done correctly you will get 2 files. A video file (with a M2V extention) and an audio file (which will be WAV, MPA/MP2 or AC3)
    Then re-author it with the subtitles using IfoEdit
    You will also probably need something like SUBTITLE WORKSHOP to make sure the subs are in a format that IfoEdit can use.
    The end result will be a no frills DVD that has no menus but it will have subtitles and it will be easy to do and you will not loose any quality in the image/sound department.
    Nov 2001
    Brasil
    Oh, Thanks for the explanation, I intend to do something alike...
    But, is it possible to make all of this(ad subtitles), and to make a Menu either???
    Thanks...
  6. Member FulciLives's Avatar
    May 2003
    Thanks...
    Well the problem with subtitles is that very few DVD authoring programs support optional subtitles.
    You usually have to spend an arm and a leg to get a DVD authoring program that does support optional subtitles.
    IfoEdit is freeware and supports subtitles but no menus.
    There is another freeware DVD authoring program that I haven't tried yet called dvdauthor 0.6 and there is a gui for it called DVDAuthorgui ... look in the TOOLS section under the DVD Author section.
    This is a freeware program that can do subtitles and menus.
    So that would be a free alternative to IfoEdit.
    Nov 2001
    Brasil
    Ok, fulcilives, Iīll try them out...
    Thanks a lot...
