I just finished the tutorial on how to make my own matrix effect with Premier Pro...now I am wondering if I can actually use it. We all know it comes from a movie, but since I DID make it, using my OWN software, does it still fall under copyright laws. The fonts are similar, but not the same. The way the rain of code drops is obiviously not the same...just wondering if my 18 hours of work can be used in promo videos (NOT PORNO)
Smile
Smile -
i believe you can use it -- its just an effect and it was used before you saw it in the matrix ...
of course lately anything is open to debate"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I would think so. Does it look exactly like the Matrix intro, or does it just borrow look & feel?
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
From another standpoint it's less of an issue of whether the effect will get you in trouble with the creators of The Matrix or if those clients that you use that effect for will make the connection and think less of it for "doing what has already been done". Be careful who you make the stuff for, unless I were specifically told to spoof a movie in some way like that on the client's project I wouldn't do it just for that fact. There's a lot of wierd clients who think they're film critics
also, hit up www.wrigleyvideo.com
curt has a tutorial on the matrix rain effect that might help you -
thats the tutorial I used. It took a while to get it down, but it was pretty cool in the end. I just wanna make something interesting...interesting for me that is...
Smile
Smile
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Exporting HD in Premier Pro
By videopetur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Jan 2009, 15:20 -
Premier Pro 3.0 - titler problem
By The Linguist in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 19:46 -
Using maya 8.5 with premier pro
By vipertongn in forum EditingReplies: 5Last Post: 8th Jul 2007, 03:29 -
Adobe Premier Pro 2 - Picture effect question
By flipzoso in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 21:54
