I am trying to convert an avi file at 23 f/p/s to DVD NTSC. I was told the only setting I need to change was the frame rate to 29.97. I did this and although it showed 199% complete, I had the following error message:
INVALID POINTER OPERATION
I tried playing the file back anyway and found the picture to be perfect but there was no sound.
Any help is appreciated to point me in the direction of a successful conversion from 23 fps.
Thanks,
Jeff
Results 1 to 9 of 9
1. Try to increase your DirectShow Multimedia Reader plugin priority
2. Use VirtualDub to extract the audio to .wav and then use that for Audio Source in TMPGEnc
3. Do the same as above except after you extract the audio, select Audio>WAV Audio from the menu & frameserve to TMPGEnc -
2nd link below.Originally Posted by aamir12345678"Art is making something out of nothing and selling it." - Frank Zappa
get rid of that ffdshow filter and install klite codec pack, TMPEGnc hates ffdshow, trust me i had the same problem.
lol, if you click on the link, it even warns you not to install all codecs included in the pack.
Tool:
K-Lite Codec Pack
This codec pack contains everything you need to be able to playback the most popular audio and video formats(DivX, XviD, AC3, WMV, WMA, MP3, MPEG2). Warning! If you install all codecs and filters you may get video playback problem. Only install the ones you need. -
If you really want to have fun then install a bunch of codecs that conflict with each other, then try to figure out which ones to delete, then try to remove them, then try to get your system to stop crashing, then try re-installing windows.
Install only codecs that you need, test your files with Gspot or Avicodec."Art is making something out of nothing and selling it." - Frank Zappa
Error message! Help!
By XAPHSNYC in forum MacReplies: 6Last Post: 8th Feb 2010, 15:05 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 13:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
