I want to add 3 movies to an iDVD project, and I want a Chapter menu for each movie. iDVD does this with no problem but I want to have the second movie start as soon as the first is finished and so on, if there is no user interaction. Currently at the end of each movie, it goes back to the title menu. I have easily done this many times in DVDSP1.5, simply by dragging the lines in a graphical view. but cant work out how to do it in iDVD. With dvdvsp I had to encode it first, but I want to take advantage of iDVDs ability to import QT movies. I do have occasional acess to DVDSP2 but haven't work out the graphical layout for that beast yet.
The map mode in iDVD seems to have no edit features.
thanking you all in advance.
I don't think iDVD can do this.
You might try opening iDVD, clicking on map and dragging all three movies to the autoplay well, then get out of map and build the menus. You'll then get autoplay and menus, but just not exactly like you wanted - the user will have to select menu to get to the menus. -
Hi,
buddy2000 said "I want to add 3 movies to an iDVD project, and I want a Chapter menu for each movie. iDVD does this with no problem" and I was wondering how to go about doing this in iDVD. Could someone explain the process of doing this to me?
Thanks,
Wolfwood87
Question about Joining movies.
By eliqush in forum Video ConversionReplies: 4Last Post: 21st Jun 2009, 14:40 -
Joining Image and Two Separate QuickTime Movies
By lindylex in forum EditingReplies: 2Last Post: 13th Mar 2008, 13:30 -
joining up .mpg movies
By natty in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2008, 07:14 -
joining avi movies
By natty in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 05:46 -
joining 2 avi movies
By php111 in forum Newbie / General discussionsReplies: 25Last Post: 2nd Aug 2007, 19:30
