Hi Major,
I have try the new option "Fast DVD" but unsuccessfully because i have a "Too many frame drops" during the multiplex process. But if I create the DVD folder manually with the 2 files (.M2V & .AC3), it works.
Encoding started on Mon Apr 12 15:24:54 CEST 2004
Input #0, yuv4mpegpipe, from 'pipe:':
Duration: N/A, bitrate: N/A
Stream #0.0: Video: rawvideo, yuv420p, 720x576, 25.00 fps
Output #0, rawvideo, to '/Volumes/Externe/MPG/movie.mpv':
Stream #0.0: Video: mpeg2video (hq), 720x576, 25.00 fps, q=3-13, 4000 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg2video @ 0x1b7ec4]rc buffer underflow
bench: utime=4623.280s
Input #0, avi, from '/Volumes/Externe/MPG/PEUR.avi':
Duration: 01:35:32.4, bitrate: 1276 kb/s
Stream #0.0: Video: mpeg4, 720x400, 25.00 fps
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
Output #0, ac3, to '/Volumes/Externe/MPG/movie.ac3':
Stream #0.0: Audio: ac3, 48000 Hz, stereo, 448 kb/s
Stream mapping:
Stream #0.1 -> #0.0
**ERROR: [mplex] Too many frame drops -exiting
I'm using the 0.0.9c version... not downloaded the new version yet.
Toche
Ti 867 MHz - 768 Mo - Airport - 10.3.4
ffmpegX 0.0.9m [REG]
Ok it works, here's the result:
Encoding started on Wed Apr 14 20:29:37 CEST 2004
Stream #0.0: Video: mpeg2video (hq), 720x576, 25.00 fps, q=2-20, 4000 kb/s
Stream mapping:
Stream #0.0 -> #0.0
bench: utime=4911.290s
Input #0, avi, from '/Volumes/Externe/MPG/CITE.avi':
Stream #0.0: Video: mpeg4, 720x400, 25.00 fps, 800 kb/s
Stream mapping:
Stream #0.1 -> #0.0
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Volumes/Externe/MPG/movie.mpg...
STAT: VOBU 16 at 1MB, 1 PGCS, 0:00:07
STAT: VOBU 32 at 3MB, 1 PGCS, 0:00:18
STAT: VOBU 48 at 5MB, 1 PGCS, 0:00:28
STAT: VOBU 64 at 9MB, 1 PGCS, 0:00:35
STAT: VOBU 12048 at 2042MB, 1 PGCS, 1:35:29
STAT: VOBU 12054 at 2043MB, 1 PGCS, 1:35:32
INFO: Generating VTS with the following video attributes:
INFO: TV standard: pal
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x576
INFO: Audio ch 0 format: ac3/6ch, drc
STAT: fixing VOBU at 1MB (17/12054, 0%)
STAT: fixing VOBU at 3MB (33/12054, 0%)
STAT: fixing VOBU at 2042MB (12049/12054, 99%)
STAT: fixed 12054 VOBUS
INFO: dvdauthor creating table of contents
scanning /Volumes/Externe/MPG/movie.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
0.48% done, estimate finish Thu Apr 15 01:47:22 2004
0.96% done, estimate finish Thu Apr 15 01:47:23 2004
99.38% done, estimate finish Thu Apr 15 01:46:44 2004
99.86% done, estimate finish Thu Apr 15 01:46:44 2004
Total translation table size: 0
Total rockridge attributes bytes: 0
Total directory bytes: 4096
Path table size(bytes): 42
Max brk space used 0
1046448 extents written (2043 Mb)
Encoding completed on Thu Apr 15 01:46:45 CEST 2004
But with the same setting, i have a bigger .mpg file.
The first one 1500Mb and the second nearly 2000Mb.
My setting was Fast DVD preset and i've change 5:1 audio in Stereo.
If i drop the new .mpg file on ffmpegX icon and check with the info button, here are the results:
Muxrate: 8:45 Mbps
Audio: Mpeg 1 Layer 3 112 kbps 44100 Hz Stereo, No emphasis
With the old .mpg file (0.0.9c):
Muxrate: 10.08 Mbps
Audio: Mpeg 2 layer 2 48 kbps 24000 Hz Dual Channel Emphasis CCITT J 17
Is it normal?
BTW, you have change the Q min & Q max default setting?
Thanks Major,
TocheTi 867 MHz - 768 Mo - Airport - 10.3.4
Are you sure it was totally muxed, start to end? As it seem your first file had a mux error.Originally Posted by Toche
Don't use the info button (I'll soon remove it), it's not as reliable as the info line which is shown above the Open.. field. Please post that information instead.Originally Posted by Toche
Yes.Originally Posted by Toche
Suggest a Fast h264 Viewer which is Frame Accurate
By VideoFanatic in forum Authoring (Blu-ray)Replies: 5Last Post: 28th Jul 2013, 11:54 -
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 02:11 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 03:30 -
Video too fast (frame rate?): FLV to MP4 with Ripbot
By JesterPoet in forum Video ConversionReplies: 4Last Post: 19th Nov 2010, 15:41 -
NetFlix Drops HD DVD
By MOVIEGEEK in forum Latest Video NewsReplies: 24Last Post: 13th Feb 2008, 19:17
