If I have the theater dts audio discs how can I rip the files from the discs so i end up with .dts files? I want to resync them with the dvd video.
get DTS-6D or DTS-6DA and a 6 or 8 channel digital input card ..
this will cost you anywhere for $7000-$11,000 plus a pc ...
I have both of the above btw ..
those are for use with film except in few cases where they have smpte sync on them for use with some custom Hd or d-cinema systems...
you are generally not supposed to have them as DTS owns them ..
the DTS proccess on theater disks is different than on what's on a dvd disk."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
Creating a Blu-ray Theater Demo Disc w/ DTS-HD, TrueHD & LPCM
By scubasteve2365 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2011, 10:00 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
Do all Blu-ray Discs contain DTS audio?
By delirial in forum Blu-ray RippingReplies: 3Last Post: 26th Jan 2009, 21:21 -
Help me create a DTS, DD, THX - DVD For Home Theater Demo
By hometechinc in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2008, 16:33
