I used to encode VCD's, SVCD's, etc with TMPGEnc Plus using 2-Pass VBR, and I would always get the results I wanted. However, about 2 or 3 weeks ago, the 2-pass VBR stopped working right. I either get an "Illegal Floating Decimal Point Calculation Order" error or the encoder produces a video that has a significantly lower average bitrate than the one that I asked for. It seems to be pretty random as to which problem I get.
I've tried frameserving, increasing the DirectShow priority, uninstalling & then reinstalling TMPGEnc, formatting Partition C: of my hard drive (leaving Partition E: with all of the GB's of videos & other files), reverting back to Windows 98 SE from XP (while Partition E: still has all of the files), etc.
Some people told me it was the particular source files I was trying to encode, while others told me it had to do with TMPGEnc's problem with encoding Divx or Xvid in general. I've checked the files for errors with VirtualDub, and it found none; so, I've tried two things. I ripped one of my Dvd's, encoded to Divx, then encoded to Mpeg2 using TMPGEnc Plus's 2-Pass VBR. I still got an average bitrate lower than what I asked for. I also took one of my very old VCD's. I did this VCD quite a while back. I tried to encode that using 2-Pass VBR in TMPGEnc Plus but got the same problem. Seems the problem isn't just Divx or Xvid.
CBR, CQ, etc work correctly most of the time, but once in a while, they have problems too. I've used other encoders like Mainconcept. It does it without any errors, but #1 : Mainconcept doesn't produce the same quality that TMPGEnc does & #2 : I've already paid for TMPGEnc Plus; I am not spending another $150 to get Mainconcept. I have tried using only the official Divx & Xvid codecs. As far as CCE Basic goes, that's also another $60. Plus, you have to learn AviSynth.
The most baffling part of all this is that my 2-pass used to work on these same exact files with TMPGEnc Plus. It seems like some configuration problem, but I haven't the slightest clue as to what. Does anybody know what's going on? What configuration settings affect 2-Pass VBR but not CBR or CQ? Furthermore, what configuration settings only affect TMPGEnc Plus and not other encoders?
Results 1 to 27 of 27
This is an example of one of my most recent encodes. I did 300 for the min, 2450 for the average, & 4600 for the max. It's almost as if it is degrading the picture on purpose:
---- 1 pass (number of pass attempted)
frame= 0 ( 20.0) Bitrate: 739 kbps Motion: 0.34 MotionScale: 0.00 CQ: 56.10
frame= 18 ( 22.5) Bitrate: 584 kbps Motion: 0.32 MotionScale: 0.00 CQ: 56.10
frame= 36 ( 22.5) Bitrate: 583 kbps Motion: 0.37 MotionScale: 0.00 CQ: 56.10
frame= 54 ( 22.5) Bitrate: 570 kbps Motion: 0.35 MotionScale: 0.00 CQ: 56.10
frame= 72 ( 22.5) Bitrate: 585 kbps Motion: 0.40 MotionScale: 0.00 CQ: 56.10
frame= 90 ( 22.5) Bitrate: 638 kbps Motion: 0.34 MotionScale: 0.00 CQ: 56.10
frame= 108 ( 22.5) Bitrate: 742 kbps Motion: 0.67 MotionScale: 0.00 CQ: 56.10
frame= 126 ( 22.5) Bitrate: 908 kbps Motion: 0.62 MotionScale: 0.00 CQ: 56.10
frame= 144 ( 22.5) Bitrate: 917 kbps Motion: 0.76 MotionScale: 0.00 CQ: 56.10
frame= 162 ( 22.5) Bitrate: 918 kbps Motion: 0.95 MotionScale: 0.00 CQ: 56.10
frame= 180 ( 22.5) Bitrate: 862 kbps Motion: 0.73 MotionScale: 0.00 CQ: 56.10
frame= 198 ( 22.5) Bitrate: 952 kbps Motion: 1.35 MotionScale: 0.00 CQ: 56.10
frame= 216 ( 22.5) Bitrate: 820 kbps Motion: 0.67 MotionScale: 0.00 CQ: 56.10
frame= 234 ( 7.5) Bitrate: 1075 kbps Motion: 1.03 MotionScale: 0.00 CQ: 56.10
Surveyed bitrate : 763 kbps average CQ: 56.10
---- 2 pass (number of pass attempted)
Req bitrate=1119.71 kbps Org Req CQ = 67.65 Req CQ = 67.65 CQ correct = 1.00 (org 1.00)
frame= 0 [I] compressed size= 16009
frame= 3 [P] compressed size= 6813
frame= 1 [B] compressed size= 2888
frame= 2 [B] compressed size= 885
frame= 6 [P] compressed size= 7039
frame= 4 [B] compressed size= 3277
frame= 5 [B] compressed size= 3987
frame= 9 [P] compressed size= 3665
frame= 7 [B] compressed size= 702
frame= 8 [B] compressed size= 2292
frame= 12 [P] compressed size= 5893
frame= 10 [B] compressed size= 2916
frame= 11 [B] compressed size= 2928
frame= 15 [P] compressed size= 6605
frame= 13 [B] compressed size= 3094
frame= 14 [B] compressed size= 918
Current bitrate = 840.04 kbps
Req bitrate=885.32 kbps Org Req CQ = 67.65 Req CQ = 68.31 CQ correct = 1.02 (org 1.07)
frame= 18 [I] compressed size= 16026
frame= 16 [B] compressed size= 4110
frame= 17 [B] compressed size= 4104
frame= 21 [P] compressed size= 4513
frame= 19 [B] compressed size= 778
frame= 20 [B] compressed size= 2831
frame= 24 [P] compressed size= 6717
frame= 22 [B] compressed size= 3347
frame= 23 [B] compressed size= 3319
frame= 27 [P] compressed size= 5500
frame= 25 [B] compressed size= 3509
frame= 26 [B] compressed size= 923
frame= 30 [P] compressed size= 7767
frame= 28 [B] compressed size= 3905
frame= 29 [B] compressed size= 3216
frame= 33 [P] compressed size= 6848
frame= 31 [B] compressed size= 802
frame= 32 [B] compressed size= 3788
Current bitrate = 873.96 kbps
Req bitrate=883.75 kbps Org Req CQ = 67.65 Req CQ = 68.78 CQ correct = 1.04 (org 1.07)
frame= 36 [I] compressed size= 15675
frame= 34 [B] compressed size= 3464
frame= 35 [B] compressed size= 3449
frame= 39 [P] compressed size= 6860
frame= 37 [B] compressed size= 3522
frame= 38 [B] compressed size= 992
frame= 42 [P] compressed size= 6902
frame= 40 [B] compressed size= 3209
frame= 41 [B] compressed size= 4261
frame= 45 [P] compressed size= 4524
frame= 43 [B] compressed size= 630
frame= 44 [B] compressed size= 3180
frame= 48 [P] compressed size= 6634
frame= 46 [B] compressed size= 3622
frame= 47 [B] compressed size= 3583
frame= 51 [P] compressed size= 7340
frame= 49 [B] compressed size= 3763
frame= 50 [B] compressed size= 968
Current bitrate = 880.09 kbps
Req bitrate=863.43 kbps Org Req CQ = 67.65 Req CQ = 69.13 CQ correct = 1.05 (org 1.08)
frame= 54 [I] compressed size= 15393
frame= 52 [B] compressed size= 3797
frame= 53 [B] compressed size= 4023
frame= 57 [P] compressed size= 4849
frame= 55 [B] compressed size= 864
frame= 56 [B] compressed size= 3427
frame= 60 [P] compressed size= 6979
frame= 58 [B] compressed size= 4167
frame= 59 [B] compressed size= 4154
frame= 63 [P] compressed size= 5076
frame= 61 [B] compressed size= 3659
frame= 62 [B] compressed size= 1087
frame= 66 [P] compressed size= 6810
frame= 64 [B] compressed size= 3698
frame= 65 [B] compressed size= 3696
frame= 69 [P] compressed size= 5946
frame= 67 [B] compressed size= 863
frame= 68 [B] compressed size= 3174
Current bitrate = 870.33 kbps
Req bitrate=886.40 kbps Org Req CQ = 67.65 Req CQ = 69.34 CQ correct = 1.06 (org 1.07)
frame= 72 [I] compressed size= 14624
frame= 70 [B] compressed size= 3561
frame= 71 [B] compressed size= 3574
frame= 75 [P] compressed size= 6155
frame= 73 [B] compressed size= 3533
frame= 74 [B] compressed size= 670
frame= 78 [P] compressed size= 7535
frame= 76 [B] compressed size= 3418
frame= 77 [B] compressed size= 4264
frame= 81 [P] compressed size= 5282
frame= 79 [B] compressed size= 708
frame= 80 [B] compressed size= 3386
frame= 84 [P] compressed size= 6307
frame= 82 [B] compressed size= 3933
frame= 83 [B] compressed size= 3872
frame= 87 [P] compressed size= 6609
frame= 85 [B] compressed size= 3627
frame= 86 [B] compressed size= 944
Current bitrate = 873.95 kbps
Req bitrate=967.68 kbps Org Req CQ = 67.65 Req CQ = 69.46 CQ correct = 1.06 (org 1.07)
frame= 90 [I] compressed size= 13610
frame= 88 [B] compressed size= 3970
frame= 89 [B] compressed size= 4024
frame= 93 [P] compressed size= 4209
frame= 91 [B] compressed size= 720
frame= 92 [B] compressed size= 2996
frame= 96 [P] compressed size= 6639
frame= 94 [B] compressed size= 3756
frame= 95 [B] compressed size= 3750
frame= 99 [P] compressed size= 7297
frame= 97 [B] compressed size= 3959
frame= 98 [B] compressed size= 899
frame= 102 [P] compressed size= 10392
frame= 100 [B] compressed size= 4780
frame= 101 [B] compressed size= 4894
frame= 105 [P] compressed size= 6815
frame= 103 [B] compressed size= 861
frame= 104 [B] compressed size= 3820
Current bitrate = 931.38 kbps
Req bitrate=4369.99 kbps Org Req CQ = 67.65 Req CQ = 69.09 CQ correct = 1.05 (org 1.02)
frame= 108 [I] compressed size= 17180
frame= 106 [B] compressed size= 4203
frame= 107 [B] compressed size= 4208
frame= 111 [P] compressed size= 7918
frame= 109 [B] compressed size= 4555
frame= 110 [B] compressed size= 942
frame= 114 [P] compressed size= 10501
frame= 112 [B] compressed size= 4861
frame= 113 [B] compressed size= 5048
frame= 117 [P] compressed size= 6597
frame= 115 [B] compressed size= 932
frame= 116 [B] compressed size= 4120
frame= 120 [P] compressed size= 8210
frame= 118 [B] compressed size= 4515
frame= 119 [B] compressed size= 4550
frame= 123 [P] compressed size= 7841
frame= 121 [B] compressed size= 4698
frame= 122 [B] compressed size= 1007
Current bitrate = 1085.84 kbps
Req bitrate=2131.69 kbps Org Req CQ = 67.65 Req CQ = 72.09 CQ correct = 1.16 (org 1.42)
frame= 126 [I] compressed size= 21675
frame= 124 [B] compressed size= 5285
frame= 125 [B] compressed size= 5723
frame= 129 [P] compressed size= 8407
frame= 127 [B] compressed size= 833
frame= 128 [B] compressed size= 4661
frame= 132 [P] compressed size= 11561
frame= 130 [B] compressed size= 7018
frame= 131 [B] compressed size= 7008
frame= 135 [P] compressed size= 12202
frame= 133 [B] compressed size= 7711
frame= 134 [B] compressed size= 1651
frame= 138 [P] compressed size= 12972
frame= 136 [B] compressed size= 7614
frame= 137 [B] compressed size= 7749
frame= 141 [P] compressed size= 12094
frame= 139 [B] compressed size= 1032
frame= 140 [B] compressed size= 5304
Current bitrate = 1497.31 kbps
Req bitrate=3110.78 kbps Org Req CQ = 67.65 Req CQ = 73.37 CQ correct = 1.21 (org 1.34)
frame= 144 [I] compressed size= 25219
frame= 142 [B] compressed size= 6541
frame= 143 [B] compressed size= 6548
frame= 147 [P] compressed size= 10811
frame= 145 [B] compressed size= 5151
frame= 146 [B] compressed size= 1383
frame= 150 [P] compressed size= 12162
frame= 148 [B] compressed size= 7292
frame= 149 [B] compressed size= 7926
frame= 153 [P] compressed size= 10404
frame= 151 [B] compressed size= 1480
frame= 152 [B] compressed size= 6267
frame= 156 [P] compressed size= 12458
frame= 154 [B] compressed size= 7593
frame= 155 [B] compressed size= 7635
frame= 159 [P] compressed size= 13665
frame= 157 [B] compressed size= 7684
frame= 158 [B] compressed size= 1238
Current bitrate = 1614.07 kbps
Req bitrate=4369.99 kbps Org Req CQ = 67.65 Req CQ = 74.12 CQ correct = 1.25 (org 1.33)
frame= 162 [I] compressed size= 24727
frame= 160 [B] compressed size= 8322
frame= 161 [B] compressed size= 8175
frame= 165 [P] compressed size= 9317
frame= 163 [B] compressed size= 994
frame= 164 [B] compressed size= 7040
frame= 168 [P] compressed size= 12691
frame= 166 [B] compressed size= 8037
frame= 167 [B] compressed size= 8034
frame= 171 [P] compressed size= 12344
frame= 169 [B] compressed size= 7519
frame= 170 [B] compressed size= 1271
frame= 174 [P] compressed size= 12839
frame= 172 [B] compressed size= 8298
frame= 173 [B] compressed size= 8394
frame= 177 [P] compressed size= 10155
frame= 175 [B] compressed size= 1329
frame= 176 [B] compressed size= 7172
Current bitrate = 1669.49 kbps
Req bitrate=4369.99 kbps Org Req CQ = 67.65 Req CQ = 75.57 CQ correct = 1.32 (org 1.48)
frame= 180 [I] compressed size= 25941
frame= 178 [B] compressed size= 7828
frame= 179 [B] compressed size= 7762
frame= 183 [P] compressed size= 11352
frame= 181 [B] compressed size= 6281
frame= 182 [B] compressed size= 1345
frame= 186 [P] compressed size= 13211
frame= 184 [B] compressed size= 8656
frame= 185 [B] compressed size= 8708
frame= 189 [P] compressed size= 10506
frame= 187 [B] compressed size= 1728
frame= 188 [B] compressed size= 7976
frame= 192 [P] compressed size= 12165
frame= 190 [B] compressed size= 8388
frame= 191 [B] compressed size= 8448
frame= 195 [P] compressed size= 13616
frame= 193 [B] compressed size= 8408
frame= 194 [B] compressed size= 1360
Current bitrate = 1744.30 kbps
Req bitrate=3539.84 kbps Org Req CQ = 67.65 Req CQ = 78.06 CQ correct = 1.46 (org 1.78)
frame= 198 [I] compressed size= 27208
frame= 196 [B] compressed size= 10183
frame= 197 [B] compressed size= 9187
frame= 201 [P] compressed size= 15704
frame= 199 [B] compressed size= 9339
frame= 200 [B] compressed size= 10454
frame= 204 [P] compressed size= 13528
frame= 202 [B] compressed size= 2163
frame= 203 [B] compressed size= 8766
frame= 207 [P] compressed size= 14102
frame= 205 [B] compressed size= 9081
frame= 206 [B] compressed size= 9051
frame= 210 [P] compressed size= 13986
frame= 208 [B] compressed size= 8927
frame= 209 [B] compressed size= 1873
frame= 213 [P] compressed size= 14154
frame= 211 [B] compressed size= 8772
frame= 212 [B] compressed size= 9352
Current bitrate = 2086.91 kbps
Req bitrate=4369.99 kbps Org Req CQ = 67.65 Req CQ = 79.28 CQ correct = 1.53 (org 1.72)
frame= 216 [I] compressed size= 29280
frame= 214 [B] compressed size= 3013
frame= 215 [B] compressed size= 8452
frame= 219 [P] compressed size= 12387
frame= 217 [B] compressed size= 8560
frame= 218 [B] compressed size= 8582
frame= 222 [P] compressed size= 12701
frame= 220 [B] compressed size= 9450
frame= 221 [B] compressed size= 2436
frame= 225 [P] compressed size= 14712
frame= 223 [B] compressed size= 9765
frame= 224 [B] compressed size= 9936
frame= 228 [P] compressed size= 12424
frame= 226 [B] compressed size= 2581
frame= 227 [B] compressed size= 9024
frame= 231 [P] compressed size= 12831
frame= 229 [B] compressed size= 9854
frame= 230 [B] compressed size= 9288
Current bitrate = 1974.44 kbps
Req bitrate=1950.99 kbps Org Req CQ = 67.65 Req CQ = 81.22 CQ correct = 1.67 (org 2.00)
frame= 234 [I] compressed size= 30873
frame= 232 [B] compressed size= 8952
frame= 233 [B] compressed size= 2425
frame= 237 [P] compressed size= 15092
frame= 235 [B] compressed size= 8660
frame= 236 [B] compressed size= 8804
Current bitrate = 2391.69 kbps
Number of encode frame = 238
Length of GOP = Average 42.50 field(s), MAX 45 field(s)
Average bitrate of video = 1334.57 kbps
VBV buffer size = 224 KB
Finished encoding video
Thanks for your "helpful" reply, Jimmalenko. I have contacted Pegasys. They simply give automated responses. They're not very helpful, and I tried their suggestions. If you don't like my posts, just ignore them & move on. Bye.
The pleasure was all mine.Originally Posted by aamir12345678
Thanks for the update. You have never mentioned in your myriad of posts about this problem that you have actually contacted them. Now I know.Originally Posted by aamir12345678
And as for ignoring your posts:
Is there something in this that I am missing ?Originally Posted by The AUPIf in doubt, Google it. -
For your information, I did not mean to crosspost. I originally thought the problem was with Divx or Xvid, so I posted in Newbie Conversion. I have now learned that the problem is with any file that I encode with TMPGEnc with 2-pass, so I thought it better if it would be in General Discussion. If you have such a problem, go to my other posts in Newbie Conversion or elsewhere & either delete them or lock them. I won't post this anywhere else. I will just wait for a reply here. Sorry to disturb you so much, Officer Jimmalenko.
Well, you did post twice at least, whether you meant to or not.Originally Posted by aamir12345678
"Officer, I did not mean to speed"
"OK I won't give you a ticket, Ma'am, if you didn't mean to"
See how lame that sounds ?
I have no problem with 95% of posters here. I have problems with those that jeopardise the future of this site. Rules are made for a reason - this site is surviving on the barest of legal grey areas and the last thing all of us need is for this wonderful tool to be shut down. If you appreciate the help (aside from all the jibes) that you get here, please pay a little more consideration to the site rules.Originally Posted by aamir12345678
Preach over.
Look I don't have a problem with you shutting the other posts down. In fact, if I could delete my own post topics, I would. If you are so troubled by this, please have the mods shut my other posts down that are too similar to this one, but not this one. This is the one I am going to stick with. I'm not asking you to "forgive" my speeding ticket. When the mods see a cross-post, they simply lock one of them; they don't give annoying, sarcastic, provocative lectures about how people like me are ruining this site. It was an honest mistake, and I'm sorry; just lock or delete the other posts too similar to this one and get off my back. You're making things bigger deals than they really are. I'm getting the feeling that your "advice" is not meant in general. Seems you are getting personal. Did I do something to you that I don't remember?
Now, what you've actually done is not useful. If you would have just reported my other post topics to the mods, they would have locked them and this would already be over, but you insisted on coming in here & sidetracking my post. Now, if someone really has useful tips for me, they will be annoyed by these long paragraphs. You could have PM'ed me. You are not a mod. You are just annoying people (not just me). PLEASE, JIMMALENKO, IF YOU HAVE ANYTHING FURTHER TO SAY ON THIS TOPIC, DON'T REPLY HERE. PM ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! -
Does anybody have a clue why the TMPGEnc's 2-pass is not working with any & all videos that I try to encode?
Again, what configuration could possibly affect only the 2-pass VBR & not the CBR or CQ & only affects TMPGEnc and not other encoders?
Any help would be greatly appreciated. Thanks. -
It can be a lot of things. Try an older version of TMPGEnc. It can be what service pack you have, or some other program playing DLL hell. TMPGEnc error problems are actually common, and there's guides just for them.
Try formatting and fresh install of XP. Then intsall TMPGEnc and try it. It should fail 100%, you have no AVI renderer installed. Install FFDShow and see how that goes.
Speaking of AVI's, do you have the problem re-encoding anything else? On old VCD or DVDR you have? You may have simply fubared your AVI codecs, in which case, re-isntalling the right AVI codecs will fix it.
You should only need to install the following:
AC3 Filter (free)
MPEG2 codec (free)
MP3 codec (LAME is free)
FFDShow
That's it. If you encode to XviD or DivX then install Xvid (RC4 is latest build?) or DivX 5.0.5 or 5.1.1 (5.1.0 had issues?). That's it. Maybe OGG-Vorbis and H.264, but that's it.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
As far as the older versions go, they will give me the bitrate I ask for most of the time, but they achieve more of a CBR. In other words, the bitrate is not varied by more than a few hundred kb/s throughout the whole video. The newest version analyzes the video properly & allocates the bitrate properly, but it seems to be degrading the average bitrate for some reason. If you look at the .log file, you see that it displays the right bitrate (based on the average I asked for) where it says "Req Bitrate" for the GOP, but it gives a significantly lower value for the "Current Bitrate" for the GOP.
Why is it degrading the average bitrate I ask for when it clearly knows it in the .log file????? This has got to be the most annoying problem I have ever come across with TMPGEnc. -
The only thing I can say about .dll conflicts is that it had the same problem with Windows 98 SE. Could the problems be about the fact that I have a permanent swap file? Does it have something to do with one of the services that are running? Is it a hardware problem? If it's a hardware problem, why do other encoders work with these same files?
Is there anyway to find out which piece of hardware is conflicting?
I've also tried to increase the average bitrate. After a few trial runs (long!!!!), I am able to get an average bitrate that I want through some calculations, but this is a tedious job. No setting can be different. You can't do a 1 min sample because it seems to alter the average you select differently based on the different motion in a movie. It may differ it 20% in one place and 10% in another and 40% in another. If I change the motion search precision to higher or lower, it will differ the bitrate differently. Further, when i do finally get the average I want, I find that some scenes go above my max setting. I set the max to 9100; it gives some scenes 10000. This is a serious problem. This is above the DVD Video Max. Does anybody understand what's going on here?
If it's a hardware problem, how can I find out which piece of hardware? -
If the some piece of hardware is conflicting with TMPGEnc, then why is it that CBR & CQ work correctly? I've tried a CBR & CQ of the whole video versus a 2-Pass VBR of a 1 min sample; the 2-Pass is still giving this problem, while the CBR & CQ work fine. If it is a hardware problem, why is it that only 2-Pass VBR is having a problem?
is there really a problem? or do you THINK there is a problem? your statement "
Obviously most of the video will have less than the average bitrate because some of the video will have more than the average bitrate.where it says "Req Bitrate" for the GOP, but it gives a significantly lower value for the "Current Bitrate" for the GOP.
This statement is pure rubbish the bitrate given out by various builds of the encoder will differ very little. It has simply had some bugs and optimizations done. Set up a new part and install things one by one, testing for three or four days btween each new program.they achieve more of a CBRCorned beef is now made to a higher standard than at any time in history.
RabidDog, I am sure that it is providing a lower bitrate for the final video. Not only does it say that in TMPGEnc's .log file that the average bitrate is less than the one that I set in the settings, but I have also taken the size of the output video and used a bitrate calculator to figure out the average bitrate of the resulting video. I am sure that there's a problem.
As far as the older builds go, maybe it was just my video or my settings, but I just threw that in to help someone figure out what's going on.
As far as the hardware problems go, I've never had a problem with overheating or anything of the sort. Encoding is an intensive task, but I have used TMPGEnc to encode using 2-Pass VBR before and it worked flawlessly. I just can't put my finger on what has changed hardware-wise or software-wise that is causing a conflict. -
No, from.
However, it seems that regardless of what I use for my Input (VCD, SVCD, Divx, or Xvid), I get the same problem.
Jimmalenko, as far as the heating problem, I've done a CBR of the whole 20 min video vs. a 2-Pass VBR of a 1 min sample, the CBR worked, but the 2-Pass VBR had the same result.
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 00:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
CBR vs 2-pass VBR comparison (really 3)
By Quantum in forum Video ConversionReplies: 28Last Post: 2nd Oct 2008, 16:20 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 15th Jul 2007, 00:24 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 19:03
