My second Netstream card just broke. While I can still author without it I have a client coming tomorrow so I really need playback. I'm assuming there has to be playback codecs that work with Meastro.
If anyone could let me know what I would need for Mpeg and AC3 playback they would be helping me in the biggest way!
true to the tri
cinemaster2000 works
its no longer made -- and really i can't help you without getting into a whole warez discussion ...
but it does work perfect ...
on your install cd -- you will also find software dvd player (cinemaster99) , its for nt4 , but it should maybe work -- if you can get it to install .. but cinemaster99 or cinemaster2000 both are the ones.. NOT the new cinemaster, which i understand does not work with maestro .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 17:14 -
Disable the playback buffer for quick interaction.
By youblokle in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2007, 17:16 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
Maybe some quick advice
By jfharper in forum ProgrammingReplies: 0Last Post: 9th Nov 2007, 22:49
