Anyone out there familiar with encoding DV to DivX with good results?
-What kinda programs do you use
-What things to keep in mind
https://www.videohelp.com/convert#4;13
what are you plan on doing with the videos you convert to divx? i wouldnt recommend it becuase you will loose A LOT of quality. -
I just want to have a small file i can put on CD.
And DivX would the best...quality/space. And compatible for other users over the net. -
I do DV -> Divx all the time.
You can fit a lot on a CD. You can do TV Quality that is about 1 hour long with proper Divx Two-Pass Encoding. If you are willing to lose some quality you can probably fit 2 hours on a CD as well. My recommendation is to use DVDs if you can. You will be able to store a lot more and it will be a lot more convient to grab one DVD vs. 4-5 CDs for the same number of videos.
Hope this helps some. -
How do you convert DV to Divx?
What kinda programs do you use for it?
What settings? -
I have done some outstanding DivX conversions. I generally use Virtual Dub to do this.
I capture from DV to AVI using WinDV or DVIO (both work well), open the resulting file in VDub, edit/filter/etc, and save as a DivX file.
I've used both 5.0.x and 5.1.x codecs with good results using this method. -
If you have an AIW, the latest version of MMC 9.0 can also do DV->Divx from the Media Library.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
