PC-Magazin (GER) 5/2004 did a review of drives and used a CATS analyzer. Someone tagged it the same thread where C't magazine did a review of drives using a CATS also. BenQ and LG rated high for + media on both reviews (and - 2x in the C't review).
PC-Magazin (GER) 5/2004:
BEST drives (grouped together, not in order of performance)
- LG 4801 / only fails on VDSPMSAB01 (DVD-R), MCC01RG20 (DVD-R), OPTODISCR004 (DVD-R) and MCI4XG01 (DVD-R). Very good dual format drive, if you avoid the crappiest media
- BenQ DW-800A / excellent drive for DVD+R burning (just as LG4801). Now if only all burns had jitter within specs and this was a true 8x dual-format drive...
WORST drives (in order of performance as rated by me based on burn test results)
1. Sony DRU-530 / only really burns ok on Ritek R02 and MCC002 (both DVD+R). REally bad drive
2. LiteOn LDW-811s / only really burns good on TYG01 (DVD-R), Ritek G04 (DVD-R), POMSC001 (DVD+R) and Ritek R02 (DVD+R). IMHO, not a trustworthy drive.
http://www.cdrlabs.com/phpBB/viewtopic.php?t=13405&start=25
Newegg is carrying the DW822A (dual layer upgradeable) now for $99 + $4 shipping.
http://www.newegg.com/app/ViewProductDesc.asp?description=27-101-622&depa=1
I religiously watch the TechTV cable channel here in the States. "The Screen Savers" is one of their shows. They had reviews of several 8x drives and the Sony DRU-530A came out on top. It is a true 8x drive in that it burns both -R and +R at 8x. It was the highest recommended drive, at least a few weeks ago.
http://www.techtv.com/screensavers/products/story/0,24330,3646325,00.html -
The only thing is at least with the linked TechTv article they did no analysis of burn quality, just burn speed.
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
Where to ger Powerbook5,3 (version 1.1) restore discs?
By Denvers Dawgs in forum MacReplies: 3Last Post: 15th Apr 2011, 10:08 -
Change region code, how? Toshiba portable DVD player (SD-P1400) 2004 model
By Traxx29 in forum Portable VideoReplies: 0Last Post: 27th Dec 2009, 19:42 -
Upgrading to 2005 from 2004 causing issue...
By Darth Paris in forum Media Center PC / MediaCentersReplies: 0Last Post: 10th Jan 2008, 21:44 -
DVD Player Compatible with 2004 Pioneer DVR 220-S VR Mode of Recording
By iloveamerica11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Dec 2007, 12:14
