  1. I'm not sure if I'm posting this in the right forum.
    I burned a DVD and it turns out to be one of those crappy DVDRs that have problems past 4G mark.
    Btw, it's a Verbatim made in India. I've been using Verbatim for ages, never a problem, and didn't really understand why people make all this fuss about Verbatim quality going down. Well, now I know. Verbatim you bunch of &@%#. Maybe I should blame the dealer too because they switched from the good Verbatims to these crappy "made in India" ones (no disrespect to the country whatsoever).
    Anyway, my problem. I deleted the original from my HD (didn't realise I'm burning on new discs; thought it's the same Verbatim I've always used). I want if possible to avoid capturing, encoding and authoring again. Has anyone successfully recovered data from bad media?
    Mar 2004
    Canada
    This may sound silly but try using a host of different readers. Sometimes media that wont read on 1 particular drive will read on another drive. If it is physically bad, then you are SOL, or so to speak.
    Good luck.
  3. ISO Buster might be able to help. It's worth a shot.
    No, I'm from Iowa. I only work in outer space.
  4. Thanks for the tips guys. I tried ISO Buster with several different drives and some managed to get far more data than others. None managed the last VOB file though but one was pretty close - only 30 bad sectors. Played it from my HD and there were only two places where some pixelation appeared. I'll visit some friends tonight to see if I can get that last VOB file without errors. If not, those 30 bad sectors are acceptable.
    Thanks again.
  5. Good luck
