I'm trying to use DVD Architect to create a DVD with multiple picture slideshow...
they are all ok except that there is the filename written on each image...
if i click each image in the slideshow and click on the text zone that contains the filename then delete it...it's ok !
but i have to do it for each picture...
there must be a way to change that setting so only the pictures show and not their associate filename ???
please help.
thanks
problem solved!
once you have created a "picture slideshow", double-click on it...
you will go to slideshow properties.
then go in menu : Options -> uncheck "Auto-Insert Slide Text".
then after that when you will drag your photos to the current slideshow or any new ones, the photos will be added without their filename.
that was the only flaw i had with this software !
Except that, WOW !
Thumbs up to DVD Architect !
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Can I change the filename order in Nero?
By DVantrease in forum Authoring (DVD)Replies: 11Last Post: 5th Oct 2008, 13:30 -
What do I do with <filename>.avi.001 files?
By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 26th Aug 2007, 06:25 -
filename with foreign characters
By namsilat in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 20:34 -
DVD player with mp3 filename on LCD display
By yoman in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th May 2007, 07:00
