Hello dear friends,
I still don't know what is causing this problem:
I burn dvd's which run perfectly on my two dvd players on the computer. The problem starts when I try to make them run on common dvd players. Three friends of mine tried it out on their machines and it allways gets either stuck or starts stuttering.
Does anyone know if it depends on the players, the disc, the editing program or anything else?!?
I realy need my works to play propperly everywhere!
Thanks!
Lozi.
Closed Thread
tmpg?
Please tell me more about it.
And; do you know if adobe premiere can also author dvd's?
https://www.videohelp.com/tools.php?tool=181#comments
You will have to use some kind of authoring tool to make a dvd.
Premiere is only editing software. You will have to encode the output
to mpeg2 and use a dvd arthoring sofware to make dvd.
Also make sure you're burning it as a DVD-Video and not DVD-ROM.
Problem with Running Vob2mpg under 'LionCamp'
By Doug Neale in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Sep 2011, 12:26 -
DVD synchronization, without synchronization device and normal dvd players
By 10shyam in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2011, 18:52 -
Problem running vob2mpg
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2010, 11:29 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
DVD FLICK running problem
By gap0306 in forum Video ConversionReplies: 2Last Post: 15th May 2007, 00:54
