hello folks
i am kindda new to adobe premiere pro .i am having problem with panning of audio.like if say some audio is in left track (which one can hear in left speaker)i wanna pan it to right .then how can we do it.entire track or say perticular clip for making some unmixed video.
thnaks
is the signal you want to pan mono or stereo?
it's been a while since I've used Premiere, and I haven't used Premiere Pro, but generally for graphic control of volume and panning, you have envelopes.
you'll see the audio as a waveform. you select the envelope editing tool and you'll see a horizontal line running through the waveform. you add points on the line with the tool, and then you drag the points either up towards the top of the waveform, or down towards the bottom.
on volume envelopes, this raises or lowers volume.
for panning envelopes, the top of the wave form will be left, and the bottom will be right, so if you drag your line down halfway between the midline and the bottom, you've moved the audio 50% to the right...
This page shows some of what I'm talking about, graphically. It's for Vegas, but I'd be surprised if it wasn't similarly set up in Premiere.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
thnaks for replying.but as u never worked on pro thats why ur treating it as its earlier versions.its not like that its completely different and there are many thing which are irritating like one can't put insert as its default.
sorry that didn't help.
- housepig
Housepig Records
out now:
Why DVD playback is jerky when panning?
By videdit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Nov 2010, 13:10 -
Horizontal panning issue
By unclechewy in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2010, 15:33 -
Remote controller and video panning
By caio1985 in forum Authoring (DVD)Replies: 10Last Post: 14th Aug 2010, 22:25 -
panning across still images
By ath1517 in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 05:39 -
Panning Menu Background
By TerryNG in forum Authoring (DVD)Replies: 11Last Post: 14th Jun 2007, 05:01
