  1. Hello folks
    Is there any possible way to "crack" a CD with copycontol? My DVD-player do not accept CopyControl, but in Norway most CDs are delivered with this crap! Since I have bought the CD, I own it, and I do want to listen to it.
    HELP!!!!!
    Rug
  2. Try turning off the autoplay function if you're using Windows.
    Or try holding down the 'shift' key as the disc loads into the machine.
    These options sometimes prevent the software based copy protections from loading
  3. Banned
    Jan 2004
    Going in Circles
    there is a program called uncdcopy. search for it on google
