downloaded a avi movie ive tried to convert it to dvdr using super dvd creator 5 it showed the movie when it was convrting. when i played back the converted movie there was no picture. so i tried converting it again usin TMPGEnc plus it was the same again. Ive converted about 12 movies and never had any problems until now. any one else ever had the same problem?
Have you looked at the video file on the DVD with your computer? You might check the files with AVIcodec or Video ToolBox and see that the video format is DVD compliant.
I would check what codecs are being used under gspot.
Anyone thinking of posting to this THREAD should read this here other THREAD first:
https://www.videohelp.com/forum/viewtopic.php?t=216911
QualityOriginally Posted by FulciLives
Trying to convert .mov to .flv - aspect ratio problems
By Graeck in forum ffmpegX general discussionReplies: 12Last Post: 21st Oct 2010, 17:55 -
Newbie trying to convert using WinFF - audio sync problems
By bogey44 in forum Video ConversionReplies: 1Last Post: 1st Mar 2009, 08:08 -
Problems getting a VOB file to play on PS3's HD, or do I need to convert?
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 12Last Post: 20th Jan 2009, 00:25 -
Attempting to convert files - problems...
By wood_e in forum ffmpegX general discussionReplies: 1Last Post: 9th Oct 2008, 11:12 -
problems with ffmpeg x - trying to convert QT and AVI files to Flash
By Aylam in forum ffmpegX general discussionReplies: 7Last Post: 17th Sep 2008, 20:50
