Hi all.
I'm looking for the best sofware and cheapest that capture from 1394 F/W, gives basic editing tools and auther dvd in a good quality.
a few options including premiere pro are too expensive for my pocket.
I know Pinnacle studio pro 9 which was alright but I havn't tested it enough, and the Wmm2 can't auther dvd.
The reason why I need it all in one software is becuse it's gonna be used by someone who is not very good with this technical stuff.
Thanks.
My thoughts would be Sonic MyDVD Deluxe, which can do what you need, but isn't too complicated or expensive. However, keep in mind that because it isn't complicated it won't do some of the fancy stuff that other programs do. However, it should be enough for your needs.
http://www.sonic.com/products/mydvd
If you decide to buy, use coupon code MSPLUS10 to get 10 off your purchase.
Regards,
Savant
Please help me,Dvd to mpeg,The most easiest way!!
By adrianneow in forum Video ConversionReplies: 2Last Post: 7th Jun 2011, 09:09 -
The easiest way to convert dvd to mp4
By karib in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 17:01 -
Best & easiest way to clone a dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 10:00 -
Easiest way to author dvd from other formats?
By Iwan2learn in forum Authoring (DVD)Replies: 10Last Post: 12th May 2009, 04:03 -
Easiest way to make a 16:9 DVD into a 4:3 XViD?
By bconnolly in forum DVD RippingReplies: 10Last Post: 31st May 2007, 16:54
