i use adobe premiere pro
i also have cce
i capture my dv and edit it in premiere.
how do i set it up in premiere to use cce as my mpeg encoder?
You'll need to install CCE's plugin for Premiere. Then you should be able to encode directly within Premiere.
Sod Out -
when you bought cce for 2000$ , it comes with it ...
you would think after spending that kind of money you would have known that .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Adobe Premiere Pro CS5.5 CUDA encoding slow??
By Brainiac in forum EditingReplies: 5Last Post: 23rd Oct 2011, 00:35 -
Adobe Premiere H.264 Encoding
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 27th Aug 2009, 03:24 -
Adobe Premiere CS4 + GPU H.264 Encoding
By deadrats in forum ComputerReplies: 1Last Post: 11th Dec 2008, 19:01 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 20:27 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 22:48
