Hello folks,
How are you all?
Sorry for the ultranoob question, but how can I determine the correct field order for an interlaced video file?
And I would like to know what is the best tmpeg´s method for deinterlacing.
Thank you very much!
Andrew
Results 1 to 13 of 13
Sounds like a plan, FOO. Been even better had you posted your script.
Hello. -
Oh, thank you for the quick reply!
But I would like to use Tmpenc to do the job.
Thanks.
Andrew -
Why deinterlace? Don't do it if you plan to watch on tv.
Use a filter in TMPGENC. Read a guide, try some at my site, it covers this.Want my help? Ask here! (not via PM!)
Sometimes you have a field based AVI and you don't know the order.
The MPEG2 encoder needs to know -
Hello,
Thank you for the answers. But how can I determine the right field order with Tmpegenc manually?
Thanks,
Andy -
A forum search for "determine field order" produces this fantastic result.
Determinng field order manualy with TMPGENC
https://www.videohelp.com/forum/viewtopic.php?t=194728&highlight=determine+field+order
Questions about interlacing/deinterlacing - TMPGenc users
By yukon33 in forum Newbie / General discussionsReplies: 9Last Post: 25th Jun 2010, 14:41 -
What is going on with Deinterlacing?!?!
By jieve in forum DVD RippingReplies: 30Last Post: 9th Aug 2009, 16:23 -
deinterlacing - before or after editing?
By jrockford1974 in forum EditingReplies: 5Last Post: 28th Apr 2009, 03:33 -
OS X Deinterlacing
By ggp759 in forum MacReplies: 4Last Post: 22nd May 2008, 17:37 -
How to use the deinterlacing in the TV when using the TV out from the PC?
By erik1958 in forum Software PlayingReplies: 2Last Post: 9th Jul 2007, 15:07
