but standalone player will.
I am having a very strange problem my computer will not recognize any types of burned dvd+r on either my dvd-rom drive. I have burned both data disk and video disks. The video disks play normally on my standalone dvd player, but when I insert them into my computer it keeps telling me to insert a disk, even though a disk is inserted. I have been able to get the sony burner drive to recognize the dvd+r disk after I updated the firmware to 2.0c.
However all my computer drives and standalone dvd player both recognize disks that I have burned on dvd-r media.
I have a sony-dru530A, using nero 6.3.0.3, and the brand of dvd+r that I am using are memorex 4x in the purple case made in taiwan.
I am just wondering how I can get my computer to recognize these burned disks.
Thanks for u're help!
Arch![]()
I have actually resolved my problem...apparently my dvd-rom did not support dvd+R media..so I went on the dell webste and was able to download the firmware to update that drive to one that does support dvd+R. I flashed my drive and no it is working properly and able to read all the dvd+R disks that I throw at it.
Oh I had a NEC DV 5800a so if anyone else has the same drive...beware u have to update the firmware in order for the drive to recognize dvd+r. Also if u have a dell 8100-8200 and got a samsang SD-616T there is a similar firmware issue... as I found when i tried to play the dvd+R on my bro's comp. Both comps now play the dvd+r fine
Hope that helps some people!
Beginners problem - Burned disks will not play.
By meditek in forum Authoring (Blu-ray)Replies: 21Last Post: 3rd Mar 2011, 15:34 -
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 15:52 -
Region coding on burned disks.
By sambat in forum Authoring (DVD)Replies: 6Last Post: 14th May 2010, 17:59 -
PC won't recognize burned files to DVD
By browndav in forum MediaReplies: 6Last Post: 9th Jan 2010, 16:43 -
Sonic won't recognize DVD, computer does ...
By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 14:06
