I have a video that is about 6 minutes or so, its basically something really slow, its a snail sliding along. I wanna speed it up to around 2 minutes. What is a program I can do this with? I have no idea on how to use Premiere (Adobe) are there any good alternatives? The video is an AVI.
Thanx for the help
-Xenogear900@yahoo.com
Ulead Video Studio will do that. You can probably just get the trial version. Put the clip on the timeline and right click on it. One of the menu choices is to change the speed.
i actually have premiere and would like to do this in premiere. i would also like to be able to slow video down for slow motion. i know how to capture at 60fps but want to slow it down o 25fps slow motion. only thing i can see is to convert it to 25fps which does not slow a video down.
i prefere premiere but can use other programs like vdub tmpeg ect -
Load the avi in virtualdub and choose video/framerate and change to 25fps for your video that is 60 fps and the other video if its 29.97 frames then change it to 90fps to get it playing 3x as fast then save as in direct stream copy mode.
ok, in premiere put the clip you would like to speed up in the timeline, (video 1A or whatever you choose) then right click it and select speed, then a little window will come up where you can enter diffrent values. 100 is normal speed, anything lower than 100 would be slowing it down (slow motion) and anything higher than 100 would speed it up. just play with that value until you find something you like.
hope this helps! -
Pinnacle Studio (I have v.8 ) does this, I've done it very successfully.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Is there any video card that can encode/convert video at lightning speed?
By johnharlin in forum Video ConversionReplies: 11Last Post: 17th Mar 2012, 15:27 -
How to speed up video conversion
By csc12345678 in forum Newbie / General discussionsReplies: 20Last Post: 15th Feb 2012, 00:43 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
How do I speed up DVD video?
By whoisus in forum Newbie / General discussionsReplies: 10Last Post: 7th Jun 2010, 16:44 -
will a separate video card speed up video encoding?
By edong in forum ComputerReplies: 12Last Post: 21st Oct 2009, 17:37
