if I have a quality capture card and I capture with preview and overlay turned off, do I need a good video card? or will it nt make a difference?
I have a osprey 200 video capture card, but a cheap vga card.
thanks
What video card you are using has no bearing whatsoever on the quality of video you capture through your capture card (assuming of course they are 2 separate devices).
Factors that have an impact: overall speed of your system, amount of ram, burst transfer rates of your hard disk (dma support). This will basically ensure that the pipeline is big enuff for the input you plan. Of course on a borderline system, turning off preview would improve the number of dropped frames slightly. Cheers
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
