This question came up in a thread in the computer section many weeks ago, but I'll continue it here. So who is going to be the first to try this? I just stumbled upon a link while reading about printing onto regular artist canvas, and he found that you needed a special coating to be able to print onto the canvas. Then he found such a product, here's what it says:
The link is:Artists can now use almost anything that they can feed into their ink-jet printers! inkAID can be used on papers of all kinds, aluminum, acrylic sheets, wood, and more.
http://www.inkaid.com/
Wouldn't it be nice if you could spray it on with an old inkjet printer?
BTW: Gesso is what you normally use on canvas before you paint it.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
did you read the directions though ? it is quite a lot of work !
http://www.inkaid.com/inkAIDwhitematteinstructions.pdf"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Yes I did. Looks like disks would need the adhesive, and then the coating of choice.
Hard Disks
By Jomapil in forum ComputerReplies: 13Last Post: 20th Nov 2010, 10:29 -
Help with Panasonic BD-RE Disks
By lee_leses in forum Blu-ray RippingReplies: 0Last Post: 23rd Aug 2010, 01:48 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
Movies on the new HD disks... why?
By Marco33 in forum Off topicReplies: 10Last Post: 24th Jun 2007, 13:34
