  1. I am attempting to author a DVD with a file from my ReplayTV that is 7.4GB (The Ten Commandments - that's one long movie). The only DVD authoring program I have is CaptyDVD which reports the file is too big when I try to use it. My thought was to author the DVD, then use DVD2ONEX to shrink it down to one DVD.
    Is there a native Mac program that can author DVDs with mpeg files this large? I am guessing that DVDSP can handle it, but I don't own a copy of it.
    Or, could I divide the mpeg into two mpeg files and make two DVDs. Can QTPro split the file?
    Oct 2003
    Canada
    Try Sizzle 0.1 after demuxing the mpeg, and create a disc image.
    http://thegoods.ath.cx/~hmason/sizzle/
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    you can author it with sizzle, then back it down with dvd2one.
    or you can split it and do 2 author processes with sizzle, then burn each one
    choice is yours
