I want to back up my X-men revolution dvd. When I use that program called "DVD2SVCD" or "DVD2VCD"...........my program Nero 6.0 can't burn it....
The movie is encoded to svcd and the movie is also .mpg......
When I load the movie, the common says on Nero, "error while encoding". I tried VCD/SVCD on nero and it tells me to encode.
How do I reconvert or what program should I use so that I can burn it?
I already use TMPGENC and it doesn't support it.
Nero 6 will not rip a DVD. Use DVDx2.2. It's simple to use. Will take about 3 hrs depending on your PC speed. After that you will need the Nero SVCD plug in to burn the SVCD. Nero 6 will let you burn VCD but you will need a plugin for SVCD. So you might want to make a VCD. It won't be as good but you can fit more on a CD-r.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 08:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23
