I've got about 15 AVI files (not sure how they were created, I downloaded them). I want to save them all on to one DVD, which should be possible based on their current size.
Guides on this site seem to imply I should convert to MPEGs first - do I HAVE to do this? What is the best route I should take?
If you want to PLAY them on a settop player, then you have to convert them. D/L AVI's are good for about 4 hours worth of DVD Video at 1/2 D1 resolution. That translates to 12 eps that are "1/2" hour each (20-22 minutes w/o commercials). 15 is doable with some work on the bitrate and simple menu.
That's all the further I'm going, you have a LOT of reading to do (you picked a medium/hard project to start out with, good luck on the Audio!!!).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
The only way around it if you want to play on a standalone is to get a DVD player that plays divx, then make sure your avi's are divx encoded or re-encode to divx as necessary. Look up divx capable players in the DVD Players section <-<-<- over there.Originally Posted by qprfact"Art is making something out of nothing and selling it." - Frank Zappa
I just open nero & drag those files to the data window & nero does the rest. Might need the converter for it.
Multi mkv files with subs into one disk to play to all bluray players
By fits79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Dec 2010, 07:27 -
Container Types Compatible with Stand-Alone DVD Players
By Groami Geistalt in forum MacReplies: 5Last Post: 12th Mar 2010, 01:20 -
Making sure AVI is compatible with DVD players
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 18:31 -
stand alone dvd players that play .wmv or h.264
By scorpio291 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2009, 11:58 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 07:59
