Hello there,
I have some really badly interlaced footage, where the "combing" effect is a blatant annoyance. I was wondering if anyone knows of the best way to correct this, maybe De-interlacing it so it does not appear? I want it to finally go onto DVD so once it has been de-interlaced, it may have to be converted again but interlaced correctly.
Here is a sample
I can reduce the combing effect by altering the fields that it encodes, but the effect still occurs when played back on TV
I am using MainConcepts MPEG Converter and its a PAL project.
Thanks for any suggestions
Your hosts keeps cutting off the download early. Cannot help.
If reversing has no effect, the problem was on the source or added with bad capture (have seen this on both Panasonic DVD recorders and with capture cards).
Either deinterlace and/or run a saw-tooth removal filter (custom made).Want my help? Ask here! (not via PM!)
Combining Interlaced and Progressive footage
By Abas-Avara in forum Newbie / General discussionsReplies: 7Last Post: 2nd Feb 2010, 16:05 -
SD Interlaced Footage for Flash Broadcast
By jbandy1 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2009, 14:53 -
XL2 - 30p footage appears as interlaced
By Tfp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 11th Jun 2008, 07:22 -
progressive footage encoded as interlaced mpeg2
By misapito in forum Newbie / General discussionsReplies: 9Last Post: 4th Mar 2008, 09:44 -
keep interlaced footage on tmpgenc xpress
By kamaleon in forum Video ConversionReplies: 2Last Post: 6th May 2007, 10:31
