ok ive actually got a list of recorders so you can tell me which i should buy feature wise or if theres a nother player i should get.
Toshiba DR1C7 £250 MAKRO
Toshiba DVDRD XS30 £380 Littlewoods aka index
Philips DVDR70 £200 MAKRO
Philips DVDR980 £250 Littlewoods aka index
Philips DVDR880 £250 Littlewoods aka index
Panasonic DVD DMRE20 £400 Littlewoods aka index
Samsung DVDH40E £280 Littlewoods aka index
Sony RDR-GX7 £??? Littlewoods aka index
Sony RDR-GX3 £290 Littlewoods aka index
ive heard good things about the GX7 i just cant decided which recorder to go for i want it to have
flex time
dvd-r recording
mulitregion
Scart
HDD
Play SVCD, VCD
if anyone can tell me which model has all that or a model i should go for id be grateful, i live in the uk btw incase its relevent. oh and yep i looked in the dvd writer/player section but theres was too much information for my little brain to take in so can you guys suggest one! thanks i think my max on a dvd recorder is about £300-£400
Okay, I'll bite. I mean, it's a no-brainer if the HDD is a "must have"; you only have to decide whether you want the Samsung or the XS30.Originally Posted by Down1oader
Understood. Also, your list contains a bunch of +R recorders while one of your desired features is "-R".
yeah i posted the ones that were going cheap at my local littlewoods store and two which i could get from makro i wasnt sure if they were +r only
Format decision for encoding for media player
By nharikrishna in forum Video ConversionReplies: 2Last Post: 7th Mar 2012, 04:22 -
The Betamax Decision
By wulf109 in forum DVD RippingReplies: 4Last Post: 7th Jul 2010, 12:28 -
HD Video to DVD and buying decision HD camcorder
By ddinc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Dec 2009, 07:17 -
HDMI splitter vs switcher decision.
By itg33k in forum DVB / IPTVReplies: 4Last Post: 1st Dec 2009, 13:02 -
Decision on YouTube proves that Capitalism has gone too far.
By Hank Kinsley in forum Off topicReplies: 102Last Post: 15th Jul 2008, 23:54
