Is there a difference in error handling for UDF or ISO DVDs, or is the error handling taken care of by the DVD-R format?
If I remember correctly: For CDs, you get the extra space for VCDs/SVCDs by using a different mode (1 rather than 2/XA or something like that) that uses larger sector sizes. This is done at the expense of error handling data that helps protect against scratches, etc in normal ISO CDs.
Does this same concept apply to DVDs? It seems to me that UDF is intended as a successor file format for ISO, and I can't find any reference to differences in error handling. Is UDF just as reliable for data storage? I'd like to backup large files using UDF but don't want to sacrifice data reliability.
Results 1 to 1 of 1
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 18:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 10:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 21:37 -
Best error handling
By demonwarrior in forum DVD & Blu-ray WritersReplies: 5Last Post: 11th Sep 2007, 04:16 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 14:10
