Results 1 to 14 of 14
  1. Hello,
    Sorry, just a beginer, wonder why all DVD R have their bottom part Blue Color type instead of regular Silver type?
    Is ther any media just a regular silver bottom one with out any brand names in inner circle or numbers?
    thanks
  2. Member 888888's Avatar
    Jan 2004
    Turdistan
    My DVD+-R bottomes are purple. You should check out the post about the difference between DVDRs and regular DVDs. It has to do with silver foil and purple dye.
  3. Is there a DVD R just same as regular ones?
  4. Member 888888's Avatar
    Jan 2004
    Turdistan
    No, I don't think so but I am not sure if it is because of technical or legal reasons.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by raxitpatel
    Is there any media just a regular silver bottom one with out any brand names in inner circle or numbers?
    What, so you can sell them to nuffies who don't know that they're burnt ?
    Commercial DVDs are either silver or gold as a result of the pressing process. I do not know of any blank media that has these traits.
    If in doubt, Google it.
  6. nope, I just wanted to know, never seen blue bottoms before.
    I've seen blue bottoms, but they were little more than coaster media. No-name crap.
  8. Member 888888's Avatar
    Jan 2004
    Turdistan
    Nuffies? Is that an Aussie expression jimmalenko? Is a "nuffie" like a guy who is asked "you call that a knife" when he takes out a small knife, or is that just someone who can't shotgun one of those giant FOSTER'S cans?
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Nuffie = Nuff-Nuff = intellectually challenged individual (not by disability I might add, just born stupid)
  10. Most of my good quality 4x discs are DARK BLUE in colour, e.g. TYG01, MCC wheras my good quality 2x discs are DARK PURPLE in colour.
    I can definetly tell a 2x TY from a 4x TY if you gave me two side by side.
    Regards,
    TerminalVeloCD
    Mar 2004
    Canada
    Colours are so subjective. While one may see blue, other may see maroon, or fuschia or purple or violet or indigo or a sanguine sunrise or a vermilion pink.
    This thread is pointless. With CD-R's colours indicated dye, but I havent seen such a pattern with DVD recordables. For instance Ritek discs are much darker than others. However it does not mean that it is superior based on the colour of the dye.
    If they work for you, then use em. Does colour really matter?
  12. I'd have to agree colour is subjective. I have a lot of fujifilm 4x Taiyo Yuden made discs and they are dark purple. Who makes the disc is more important than what dye colour it has.
  13. It's a combination of the color of the dye used and the color of the reflective layer used. Color is in no way a guaranteed sign of quality.
  14. nope color is not a matter, I just wondered since never seen dvd r before Just stepping in.
