I got a new plextor px708a dvd burner.
So I've just been figuring out how to backup dvds, but I'm having a problem. Whenever I'm decrpyting the dvd using decrypter.......it only reads at about 2x (sometimes 2.1, 1.9 etc)
I have the settings to max read rate, but for every dvd I've tried so far it reads at 2.0 speed.....
The drive can read dvds at 12x........ is ther any way to speed it up?
I believe if u change the setting from max to to the actual read speed of ur drive it might run better..
I came I saw I conquered......... -
http://club.cdfreaks.com/forumdisplay.php?s=ed0843767e459c8ffd3544f0293b894f&forumid=43
Check the above Plextor forum. Below is a quote from Plextor Forum:
I would suggest you get a dvd-rom to do the ripping of the dvd movies. I have the Plextor 708A drive but only use it to burn dvds. I use my Toshiba DVD-ROM 1612, 1712 to rip my movies.My Plextor PX-708A drive only reads DVD-Video discs at 2x! Can't I make it go any faster than that?
A Yes, you can 'unlock' the drive by making sure the drive is empty and closed. Then press and hold the drive's eject button for about three second until the drive's LED flashes green three times. Release the eject button so that the drive's tray will open. Now insert a DVD-Video disc and voila the drive reads faster. When you eject the disc or when you cut the drive's power, the PX-708A will be reset to 2x reading again. -
WEll that manual fix works.....but I wish there was a hack that would make it automatic.......
jimmalenko wrote:
Unfortunately their isn't one for this Plextor model. The best bet would be to get a dvdrom to do all the ripping.Isn't it just the 2X ripping restriction on burners ? I'd look for a firmware mod to unlock it permanently
HL-DT-ST DVDRAM GSA-T20N read speed too slow!!
By tmangia in forum DVD & Blu-ray WritersReplies: 10Last Post: 17th Aug 2010, 06:44 -
Really slow external hard drive. WTF?!
By dafoe in forum ComputerReplies: 8Last Post: 25th Sep 2008, 04:19 -
Slow Read Rate
By mr240 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2008, 18:41 -
Slow DVD drive (LG GSA-H42N) problems
By cosmo09 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Sep 2007, 01:51 -
Slow performance for HP 740b drive in VISTA
By fanch16 in forum DVD & Blu-ray WritersReplies: 3Last Post: 19th Jun 2007, 02:33
Glad it worked for you.
