In another thread, Diva was recomended to convert a VOB file to DV for editing. I decided to try this just to see how it works. My question is this: When I try to choose DV as the format for export, I see several different options except DV-NTSC. I don't understand why it isn't in the list. I know it's there when i'm using Quicktime Player Pro, so where did it go?
Should I just choose another DV format, then convert it again in QuickTime Player Pro? If so, which format should I use when exporting from Diva?
DVCPRO is better than DV. Not sure if 50 is better than regular DVCPRO, but either should be fine. I think DVCPRO50 is a lot higher bitrate, and so will require more HD space.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Originally Posted by Manny C
DVCPRO 50 is different it has a bitrate of 50 MBps as opposed to the 25 in DV/DVCPRO. You can use DV/DVCPRO tape in a DVCPRO 50 cam but it will have half as much recording time. The higher bitrate allows for more video information. If you have a DVCPRO 50 camcorder/vtr then you probably paid plenty for it, and hopefully knew why you were buying it. You don't need my $.02.
Subtitle question for PS3 owners and experts....
By siratfus in forum SubtitleReplies: 1Last Post: 25th Jul 2008, 23:27 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
This Is A Loaded Question For You Video/Audio Experts Out There...
By pmolson in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2007, 13:32
