Hi, I've been having some trouble converting some DivX and XviD AVI's to SVCD's. I've used two methods so far on each of the movies but get the same results.
1) When I try using DVD2SVCD the first disc will usually be fine but the audio in the second disc will be completely out of sync with the audio being 2-5 seconds ahead of the video.
2) When I try using Gary's Foolproof AVI to SVCD Guide (available on this site) which involves using VirtuaDub MP3 Freeze to check for bad frames (which it finds none), then using normal VirtualDub to extract and resample the 2 channel stereo sound, then use TMPGEnc to convert the video and merg the audio I get similar results with the first disc in sync while the second disc is out of sync.
Some movies convert fine, but some just won't stay in sync. Is there something I'm doing wrong? Is there an easy fix for this? If I tried converting it to one big file then splitting it to multiple CD's whould that be easier?
PLEASE HELP!
Results 1 to 1 of 1
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
