Results 1 to 23 of 23
  1. Member Sakuya's Avatar
    Dec 2002
    Hi. I want to rip but there are several VOB files. The DVD says that the disc has 3 episodes. How do I know which is which?
  2. Originally Posted by Sakuya
    try playing them?
  3. Member Sakuya's Avatar
    Dec 2002
    I did. And this is weird. The original DVD has three episodes. WHen I opened the DVD, here is its contents:
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VIDEO_TS.VOB <-----copyright ad
    VTS_01_0.IFO
    VTS_01_0.BUP
    VTS_01_0.VOB <-----menu
    VTS_01_1.VOB <-----start of episode 1
    VTS_01_2.VOB <-----continuation of above
    VTS_01_3.VOB <-----continuation of above
    VTS_01_4.VOB <-----continuation of above
    VTS_01_1.VOB is the start of episode 1; meaning it contains opening credits as well as the episode number. However, at the end of this clip, it kind of cuts off. But, it continues in VTS_01_2.VOB and then after 34 minutes, it cuts off. Continues in VTS_01_3.VOB and so on. Where do I find episodes 2 and 3? I don't get it. The original DVD is PAL so I'm trying to copy each episode onto my computer, convert it into NTSC and then burn it back onto a DVD+RW for my friend (he doesn't have a PAL DVD player). Where is episodes 2 and 3 hidden?
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Just open with DVD Shrink and use it as a ripper, can't go wrong.
  5. Ah ya, a friend encountered that problem with his Stargate DVD set.
    In the simplest case you got a new vob for each episode, but it seems on your DVD (as well as my friend's Stargate DVD set) an episode uses several vobs as well as several episodes use the same vob.
    (in real english this means that there is more than 1 episode in each of your vobs which can cause trouble if you are trying to rip/backup the DVD since your software might only see the first episode)
  6. Member Sakuya's Avatar
    Dec 2002
    Ok, after loading the DVD's contents, what do I do next? I don't want the menus. Just the episodes.
  7. Member Sakuya's Avatar
    Dec 2002
    Yes, I just found a tool that can fast-forward through each VOB better than WMP. And I did find episode 2 and 3 in one of those continuation VOBs I mentioned above.
  8. Member steveryan's Avatar
    Jan 2003
    Manchester
    Hit the re-author button, choose your episodes, compression etc then hit backup.
  9. Member Sakuya's Avatar
    Dec 2002
    But I must switch the PAL videos to NTSC somewhere right? Can DVDSHrink do that?
  10. sounds like the dvd only has one title with all episodes combined into that title track. you can use dvdshrink to cut each episode into separate titles by using the start/end button.
    so you would do something like this.
    -load the dvd files into shrink
    -click on reauthor
    -move the title track over from right to left.
    -click on start/end.
    -choose the start and end of the first episode.
    -click on backup
    -repeat for all three episodes.
    no dvdshrink can not convert pal to ntsc.
    I would recommend searching the guides on how to convert pal to ntsc.
  11. Member Sakuya's Avatar
    Dec 2002
    Thanks. But the each episode is still split:
    VTS_01_1.VOB
    VTS_01_2.VOB
    VTS_02_1.VOB
    VTS_02_2.VOB
    VTS_03_1.VOB
    VTS_03_2.VOB
    Each episode is still split into 2 VOBs. Now what?
  12. like i mentioned earlier, you want to do a search on how to convert from pal to ntsc, unless of course, you have a dvd player that can play pal dvd's.
    PS. please don't come to the boards expecting to be spoon fed, and hand held till you solve your problem/s. read the guides. There isn't a problem I haven't been able to solve after reading over the guides.
  13. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You asked:
    You now have each episode in its own set of VOBs. That is what you asked. Nowhere have mentioned any further goals.
    If in doubt, Google it.
  14. Member Sakuya's Avatar
    Dec 2002
    Sorry. I found a weird problem. When I re-authored using DVD Shrink, I opened the first episode in TMPGEnc to encode and it was fine. But when I opened VTS_02_1.VOB and VTS_03_1.VOB, there was no sound. However, VTS_02_2.VOB and VTS_03_2.VOB has sound. Why is this?
  15. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    PEBCAK.
  16. Member Sakuya's Avatar
    Dec 2002
    What is that?
  17. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by jimmalenko
    PEBCAK.
    Problem Exists Between Chair And Keyboard
    It means the the user has done something wrong.
  18. Member Sakuya's Avatar
    Dec 2002
    I found out in DVD Shrink that the DVD has 2 types of audio. One of them is AC3 5.1 while the other one is normal MPEG audio. But, when I click on "re-author", the choices disappear and you cannot choose which audio. I dragged Title 1 into the right hand side and set the start/end times. I then clicked "back up" and it backed up as VTS_01_1.VOB and VTS_01_2.VOB.
    They are 2 segments of episode 1. I want to open TMPGEnc and then click "open sequence files as a movie." But when I selected VTS_01_1.VOB as the video source, the audio source is blank. When I selected VTS_01_2.VOB as the video source, the audio space is automatically filled in with the same filename as the video source. That's weird. I opened both VOB files in VDubMOD and they both have AC3 streams. This is so confusing. If I convert them as is, wouldn't one part have no audio and the other part have audio?
  19. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I foresee two options here - the easy way and the hard way.
    The easy way involves smashing your keyboard over your head.
    The hard way involves a lot of reading.
    How's it gonna be ?
  20. ok, i'm bored so I will tell you how i would do this.
    the video and audio need to be processed in two parts.
    VIDEO
    -open the first episode using dvd2avi
    -click file | open | select the first vob of the first episode and dvd2avi will select the rest of the vob's for that episode.
    -then click on file | save project
    -name the project what you want and save to the hd.
    -repeat these steps for all 3 episodes
    -load the project file dvd2avi created in tmpgenc
    -convert the file from pal to ntsc and mpg 2 dvd standard.
    -the most important settings for this is are:
    1. change the framerate to 23.97
    2. select 3:2 pulldown
    3. on the advanced tab, check do not framerate convert
    -convert only the video stream (ES (elementary stream)->video only)
    -you should end up with 3 x m2v files for each episode
    AUDIO
    -open up the first vob file for the first episode with dvd2avi again
    -click on audio | track number | select the track you want if there are more than one
    -click on audio | output method | decode to wav
    -click on file | save project
    -save the file to your hd.
    You could actually do this at the same time you're demuxing the video stream but I separated the steps for simplicity.
    -load the wav file using goldwave or other audio editing software
    -click on effects | time stretch
    -slow the audio down to 23.97 fps
    -save each audio file to your hd as 16 bit pcm wav
    -optional: load the wave files into ffmpeggui and convert wave to ac3
    -you should now have 3 x wave or ac3 audio files
    MULTIPLEX, AUTHOR, and BURN
    use an authoring program such as tmpgenc dvd author to multiplex the files together to create menus and dvd compliant vob files.
    -load each m2v file with it's corresponding ac3 file
    -eg. episode1.m2v and episode1.ac3
    burn the vob files using your favorite dvd burning software.
    not sure if that's the best way or the fastest but it will work. Hope that helps.
  21. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Good call Dafreak. That's how I would have done it.
  22. Member Sakuya's Avatar
    Dec 2002
    Actually, I found a better way. I used VOBMerge to merge the 2 VOBs together. Then I used VDubMOD to extract the AC3 and then load the joined VOB to TMPGEnc to convert to an M2V. Thanks.
  23. Originally Posted by Sakuya
    like i said, my method isn't the best way, not sure if there is a "best" way, but it will work. There are many different ways of approaching this. I'm glad you found your own method. More power to you.
    if you use the ac3 file that you extracted without modifying it, you'll end up with synch problems.
    if you're going to use virtualdub to extract the audio, use the save wav function. Save it to wave, slow the audio down to 23.97 and then convert back to ac3
