Nero 6 Transcoding Problem... AARRRGGGHHH!
Hi,
when nero starts transcoding files for a VCD or SVCD, it gets to the end of coding the first file and then it just hangs! i thought it might be the avi video files that i was using, so i tried it out with normal Mpeg files and it still hangs! No other programs like virus checkers etc are running at the same time... so it cant be that and i am using the latest nero encoders....?
I am getting frustrated with my PC now and unless anybody has any ideas, i will be forced to take a piss on the keyboard! and kill the cpu with a grinder!
Any Ideas?
__________________
Compaq Presario AMD 1.0Ghz 128MB Ram 30 Gig Drive.
Originally Posted by accessfmWell...where do I start...Originally Posted by accessfm
If this is your attitude, you are not gonna get any help here. Lose the attitude and acquire some patience and watch your results improve.
Video is not for the impatient.
It is well known the Nero's trnascoding engine is subpar in comparison to a dedicated encode such as CCE or TMPGEnc. All you need to do is encode to the format and specifications you require, then turn off the standard compliance in Nero and it will burn whatever file you throw at it without re-encoding.If in doubt, Google it. -
I second bumfluff's motion (haha).
Nero transcoding engines have been found to be utterly unreliable since day 1. If you d read half the comments made about it on this forum you would know.
TMPGEnc, on the other hand, produces reliable results consistently, is not difficult to use and is an inexpensive solution.
Why you had to blast jimmalenko for his helpful answer, I have no idea.
Transcoding Software
By Prince Valiant in forum Video ConversionReplies: 4Last Post: 11th Sep 2010, 11:26 -
Freezing during transcoding in Nero Vision 4
By TheGMan in forum Video ConversionReplies: 2Last Post: 21st May 2008, 11:09 -
Different Transcoding on Encore
By htalnts in forum Authoring (DVD)Replies: 1Last Post: 14th May 2008, 23:42 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 15:23 -
I keep getting an Error while transcoding with Nero Vision 3
By kiaconcepts in forum Video ConversionReplies: 4Last Post: 5th Jun 2007, 08:35
