a good tip from our friends at pixeltools:
Glitch less looping provides restrictions on the MPEG encoding, the multiplexing, the server (or system that controls the MPEG stream looping) and the MPEG decoder. Your best chance at successful looping is to set up the elementary video decoder to have the identical starting and ending video buffer
Set the Optimize Encode | Rate Control | Final Buffer Fullness and Optimize Encode | Rate Control | Starting Buffer Fullness to be equal. You can use 20000 bytes as a starting number. Also, uncheck the Optimize Encode | Parameters | Sequence Style | End of Sequence. An end_of_sequence header will NOT be inserted at the end of the stream.
It is sometimes required to add stuffing packets in the Program or Transport streams between stream to compensate for irregularities in the server looping. Stuffing packets can be Transport packets with only stuffing bytes. Sometimes just adding a lot of 0x00s or 0xffs to between streams helps with glitching. You can experiment with your system to see how many stuffing bytes are useful.
Results 1 to 1 of 1
Ideas or tips for building computer (mostly for video editing/encoding)
By robjv1 in forum ComputerReplies: 13Last Post: 14th Jun 2011, 14:21 -
need encoding tips for better quality PS3-friendly MP4
By spicediver10191 in forum Video ConversionReplies: 6Last Post: 13th Mar 2011, 05:48 -
MPEG2 Rendering Tips
By Surya in forum Authoring (DVD)Replies: 32Last Post: 1st Oct 2010, 19:03 -
Seeking audio encoding upgrade tips
By vhelp in forum AudioReplies: 2Last Post: 25th Jan 2009, 19:33 -
Lower video encoding tips for small 7 inch screen
By hauns in forum EditingReplies: 5Last Post: 9th May 2007, 13:54
