thought nec 1300 is supposed to burn + and - however the nec 1300 refuses the emtech dvd-r.
anyone same experience?
thanks and regards
yes, the Nec 1300 a is very good machine but rather picky on the quality of DVD+/-R you put in
Emtec is not a reliable brand: apparently they simply buy eand resell discs from various sources: Taiwan, Europe etc... the results vary a lot from batch to batch -
I have it and no, it doesn't burn emtec -r dvd, but it burns very well emtec dvd +r, i tested many brands and this burner burns for me better +r media.
You can use maxell -R if you want -r media. -
While the NEC burners are ok as far as the electronics goes, the firmware is terrible. Take it back and get a Pioneer, Lite-On or Sony if you want to burn most of the media out there.
C 1300 disc is dirty error on NEW blank dvd's
By rrtbusa in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd May 2010, 09:25 -
Hauppauge HVR-1300 and Virtualdub Cannot Capture
By JonnyAlpha in forum Capturing and VCRReplies: 5Last Post: 13th Feb 2010, 10:39 -
NEC DVD-RW +ND-4551A won't burn DVD-R DL
By Belfour in forum MediaReplies: 11Last Post: 5th Jan 2009, 05:32 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13
