With the intent to encode to mpeg2 or mpeg4, is it a good idea to try to remove some of the grain and noise in the original DV files that I transfered over from a D8/Hi8 player with DV over Firewire capabilities?
If so, how do I do that? Will Premiere 7 do that, or get a 3rd party program to do it?
Thanks!
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Filtering will remove noise, usually with some lose of resolution. Virtualdub, TMPGEnc both have noise filters. Virtualdub seems to have more filters/options. Noise filtering will generally improve the picture if it's noisy, but will add to the encoding time if used while encoding, sometimes by quite a bit. I filter DV in Virtualdub and frameserve the result to TMPGEnc to save some time and HD space. Old VHS tape really benefits from filtering, but it takes a long time to do a adaquate job. You need a fast computer and a lot of spare time to do it right. Filtering random noise will give you a slightly faster and better encode, though.
Grain Removal filters for Avisynth
By Legendkiller in forum EditingReplies: 0Last Post: 10th Oct 2011, 22:29 -
Removing/toning down digital noise/grain on HD video source.
By Killer3737 in forum Video ConversionReplies: 22Last Post: 27th Jul 2011, 18:37 -
Grain/noise removal software for macs
By Lexa in forum CapturingReplies: 0Last Post: 8th Jun 2011, 18:05 -
Help with avisynth filters, removing grain, dust or spatial noise
By greyfalcon in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2010, 11:08 -
Canon Xh A1s Grain/Noise
By mseidner24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Feb 2010, 17:05
