I an trying to convert bin and q files so they can be burnt as a DVD They are in seperate files as two discs ). I was advised to use VCDGear which has changed them to a Mpeg, but when i try and load them into TMPGEnc to burn as a dvd one gives the fault that the GOP is too big and the other that the video resolution 480 x480 cannot be used for a standard DVD. Being new I am now STUCK can anyone help or direct me to a "how to " site ????
Many Thanks
TMPGEnc will commonly give you a 'GOP too long' error when you go from a SVCD to a DVD. I, and many others ignore this and burn anyway with no problems. If VCDgear modified the header properly 480x480 should work also. (Sorry, I don't use that program) The audio needs to go from 41K to 48K to be compliant. You might try burning as a RW to see if it works properly. I use SVCD2DVD and it works fine, though I hate the .net program it needs.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 09:52
